Amsoil
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Anyone try Ames oil and if so how much should I use per gallon?...
Old 05-15-2008, 10:51 AM
Default Amsoil
Old 05-15-2008, 11:06 AM
Ilikeabikea's Avatar
Default Re: Amsoil
Pablo is an Amsoil dealer. I bet he can give you all the pertinent info................
http://bdconner.com
Old 05-15-2008, 12:45 PM
Default Re: Amsoil
Pablo, I do not see Pablo on the members list.
Old 05-15-2008, 01:02 PM
Default Re: Amsoil
Pablo has an add at the left of the page. Look under the P on the member list. His is the first name.
Old 05-15-2008, 05:13 PM
Pablo's Avatar
Amsoil Dealer
Default Re: Amsoil
Quite few fellows are running one of the three Amsoil 2-stroke oils. See the for sale thread at the bottom for my special and oil description.
Mix ratio depends on the oil, your conditions,your fuel/air mix.
Saber is the most common and protects the best. 30:1 is even pretty oil rich with Saber. 40:1 is fine for a well broken in engine. The oil is designed to work up to 100:1.
I have been using Dominator at about 30:1.
http://oilslubesfilters.com/
CRUISER's Avatar
ADMINISTRATOR
Default Re: Amsoil
i use the amsoil in my motorized bicycle gas tank andi think it is awesome. more expensive then regular 2 stroke oil but i want to get as many miles as posible out of my bicycle engine
Old 05-15-2008, 07:05 PM
Norman's Avatar
LORD VADER Moderator
Default Re: Amsoil
Amsoil is very high quality oil or I think one of the best there is.
norms-iron-works.tripod.com
Old 05-16-2008, 12:27 AM
Default Re: Amsoil
TYPICAL TECHNICAL PROPERTIES
Saber™ Professional Synthetic 100:1 Pre-Mix 2-Cycle Oil (ATP)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
13.5
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
99
Viscosity Index (ASTM D-2270) 136
Pour Point °C (°F) (ASTM D-97)
-36 (-33)
Flash Point °C (°F) (ASTM D-92)
114 (237)
Fire Point °C (°F) (ASTM D-92) 114 (237)
  #9 (permalink)
Old 05-16-2008, 12:29 AM
Default Re: Amsoil
Maxima 927
Gravity °A.P.I. 17.6
Viscosity SUS @ 100°F 617
Viscosity SUS @ 210°F 73
Viscosity cSt @ 40°C 133.1
Viscosity cSt @ 100°C 13.79
Pour Point, °F -5
Flash Point, °F 420
Fire Point, °F 480
Viscosity Index 99
SAE Viscosity 40
  #10 (permalink)
Old 05-16-2008, 12:33 AM
Default Re: Amsoil
Synthetic 2 stroke oil only lubricates as a liquid. Once it is "flashed"at 237 deg F it no longer works.
Maxima 927 doesnt'flash until 427 degF and when it does flash, it firms dry polymers that provide even better lubrication as a dry lubricant. Its high flash point means you 'll see unburnt oil in the exhaust. Contrary to what Amsoil dealers will tell you, this is GOOD and not bad. The longer it is a liquid, the better lubrication it can provide. Specs and facts can't be argued.
Oh, I did have a lot of training as a tribologist as a test pilot in the military. For what it is worth,we never changed oil in turbine engines based on a schedule. All oil was sampled regularly and sent to an oil analysis lab. Lab would let us know what action we had to take and what wear we were seeing in the engine.
I'll convert the specsfrom SUSto Cst when I have time for comparison.
Similar Threads
Amsoil 2 Cycle Synthetic Oil Sale Pablo Swap Shop 32 05-31-2008 07:18 AM
