| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | accidentally solving a problem Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I have been having a hard time with my carburetor leaking (bad). I have been trying to find out what ...  | |
07-01-2008, 10:40 PM
| | Master Motorized Bicycle Builder | | Join Date: May 2008
| | accidentally solving a problem I have been having a hard time with my carburetor leaking (bad). I have been trying to find out what was wrong with it but with my limited knowledge I could not. I was beginning to think that I was going to have to take the carburetor apart or get someone to do it for me. However, my engine was not idling and I messed with the idle screw today a bunch until I finally got it to idle. Here's the thing; Now that I got the bike to idle good, I don't have the bad leaking problem anymore. Does this make any sense to anyone? I'm new at working on these things and don't really know if it makes sense or not.
I would really appreciate any help and comments. Thanks |
07-01-2008, 10:57 PM
| | Re: accidentally solving a problem Your float level may be a little to high (letting to much fuel in carb bowl).. Now that you got it to idel, you are using that little extra fuel in the carb bowl. So, there is no excess fuel to leak out. That's what I come up with  |
07-01-2008, 11:25 PM
| | Master Motorized Bicycle Builder | | Join Date: Feb 2008
| | Re: accidentally solving a problem your float may have a small leak. check it. Enjoy the ride. |
07-02-2008, 08:25 AM
| | Re: accidentally solving a problem Thanks for the responses everyone. And Fairracing, that makes sense to me. I think that is what is happening. Thasdax, you are right. I still have a small leak. I think it's coming from one of two places. First, where the fuel line attaches to he carburetor or second, the float is sticking. I'm going to put new fuel line on it but if it's the float sticking, I'm a little nervous about taking the carb apart. I'm not much of a mechanic and don't know if I could get it back together and in working order again.
Would spraying carburetor cleaner help any? Just a thought. |
07-02-2008, 08:42 AM
| | Re: accidentally solving a problem Don't be afraid to take it apart. Here's a link to Normans carb rebuild. He even took pictures so you can see what he's talking about....................... Motorized Bicycle Carburetor install and rebuild
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
07-02-2008, 08:45 AM
| | Re: accidentally solving a problem Thanks man... I will check it out for sure. BTW: I love your sig. I'm a retired software developer.
07-02-2008, 01:10 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: accidentally solving a problem I like the sig too. I'm not a retired software developer though, I'm just a huge nerd  |
07-02-2008, 04:21 PM
| | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: memphis tn
| | Re: accidentally solving a problem Quote:
Originally Posted by jasonh I like the sig too. I'm not a retired software developer though, I'm just a huge nerd  | ^^what he said |
07-02-2008, 11:02 PM
| | Re: accidentally solving a problem sometime the brass nipple that the fuel line attaches to isn't tight and it will seep fuel very gentle tighting will help if its loose. The fuel line also likes to leak on that brass fitting as well I use stainless steel safety wire as a hose clamp to seal that off it hard to get a regular hose clamp on that small line.
Does the wire work you ask well I have a home built airplane and that is what I use on the fuel tanks sight glass clamps and in 23 years no leak.
Norman |
07-02-2008, 11:36 PM
Originally Posted by Norman sometime the brass nipple that the fuel line attaches to isn't tight and it will seep fuel very gentle tighting will help if its loose. The fuel line also likes to leak on that brass fitting as well I use stainless steel safety wire as a hose clamp to seal that off it hard to get a regular hose clamp on that small line.
Norman | Thanks Norman, I will check that in the morning. Right now gas is pouring out and I'm not sure where it's coming from. I need to take a good look at it and I will do that tomorrow. I will let you know what's going on when I know more. Thanks a lot.
cd | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:18 AM. | | |
