There has been a lot of discussion about clutch/chain noise from the 2 stroke Chinese engine. I've found one source that anyone with a Dremel tool or a grinding stone in a drill can cure. Both of my engines, one from Dax, the other a Chris Hill motor, had chain interference with the clutch actuator cover. The photos show where I found the chain was hitting inside the cover and what I did to eliminate the contact. After this modification my clutch/chain noise was dramatically reduced. It's easy. Give it a try.
Remove the clutch actuator cover, look for the telltale marks on the inside of the cover where the chain has been hitting. (photo 1) I used a Dremel tool with a sanding drum but any abrasive tool will suffice, to remove enough material to widen the space between the cover and the chain. After grinding the relief area I installed the cover and spun the rear wheel with the clutch dis-engaged, and looked for any spots that were still hitting and then ground off just a little more material.
The attached photos are self explanatory. Any questions, just ask.
Oh, and before you tell me my chains are too loose...no, they're not.
