2-3 second delay on start
corduroylion
norcal
hey guys...
when i peddle and then release the clutch to start the engine it takes about 2 seconds for anything to happen... ? even then with some gas its hard to get it to turn over. what would caue this?
once i get it running its fine and runs great but just starting it is a pain.
corduroylion
norcal
before, when i release the clutch the engine would make noise right away... now there is a delay before anything happens, even after i give it gas.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Your clutch is slipping a little. Take the cover off, pull the clutch in and lock it and spray the inside of the clutch with some brake cleaner and clean out all the crud and grease in there.
If that doesn't do it, you may have to make a clutch adjustment.
