I havent done a lot of riding, but i just noticed that i have evidence of oil leaking from the seams between the head AND the seam between the top (main cyl?-the thing with the horizintal fins on it) and bottom end.
I dont see any gasket material hanging out-just oil oozing out of the seams.
its not REALLY bad, but i know its not supposed to be there
i cant really get a good picture of it but it is similar to thie 1st pics in this thread:
http://motorbicycling.com/f52/replacing-head-gaskets-25877.html
...just no gasket material
I have a pirate cycles high compression head
I already bottomed out the head studs and loctite'ed them
tightened the acorn nuts to 15ft/lbs...made sure the weren't bottomed out
the head still leaked oil and i just noticed the bottom.
because its such a close fit into the frame and theres not enough thread exposed to jamnut the studs to rmove them, ill have to pull the whole motor to get the head off. Needless to say, i only want to do this once.
Is the leak affecting the motor, or is it just messy?
Do i need to replace the gaskets?
If so, are there a reliable replacement gaskets?
thanks
thanks
