intake for cylinder with 40mm spacing
born to be mild
7
maryland
Hi, have new cylinder and piston. now I'm in need of intake manifold with 40mm stud spacing for stock carb. Any info on availability would be welcomed. Have not seen any listed with dealers. Thanks Tim
hotrodrob21
5
riverside, ca.
making it bolt up will be easy, but the correct intake will be a lot better, the opening is wider to match the port. the superrat has it. where did you get the cylinder?
born to be mild
7
maryland
bought the cylinder and piston from "Bicycle engines . com" So far haven't seen parts listed for Super rat motors offered by vendors. With the larger intake port it look like it should breath pretty good . Geting 27mph on flat ground with stock 48cc, would just like better low end performance
troyboy
Your East Coast Gasbike Connection
Apr 18, 2009
171
Wista ma
If you want to order a standard billet intake from us we have a few with 40MM spacing.. When you check out write in the comments box that you want one with the 40MM stud spacing and I will send you a billet intake w 40mm stud spacing. I have 3 in stock right now if your still looking. Just thought I would run it by you.
Thanks
Justin
