Titan bogging under throttle
Jonesey
4
Littleton, CO
My Dax Titan has been bogging down and wanting to die while under throttle. It idles fine, but when I apply the throttle it wants to die. I changed the gas out and drained the carb and it ran fine for several miles. Now its doing it again. Drained the carb again....ran okay for half a mile....doing it again. I can't belive I got bad gas from two different gas stations. Any suggestions?
Oh, and I keep the gas cap loose.....had that problem a while ago.
thatsdax
868
4
16
www.thatsdax.com
drop your bowl, and then pull and clean the main jet. Also. You can remove the black plastic idle screw, and then remove the black plastic plunger. There is a slow jet there that can also be cleaned. Once you get both jets cleaned, it should run fine again.
