Won't Start
Discussion in 'Motorized Bicycle General Discussion' started by oldsurfer, Jun 25, 2010.
  1. oldsurfer
    oldsurfer New Member
    May 21, 2010
    126
    i had my 66 cc bike all done and was running fine got it home and noticed the green ground wire was lose..secured it to the front motor mount bolt ....the damn thing will not fire up....there are only 3 wires to look at the black and blue...as i rember..these 2 come from the magneto and go to the cdi...then there is the ground wire and the kill switch wire...all appear good connections....is the ground wire not in a good place were i have it?..what is the problem....is seems no spark.....help!!!!!!laff
  2. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    Start with the easy things. Disconnect the kill button and see if that fixes it.
  3. oldsurfer
    May 21, 2010
    126
    how do you disconnect the kill switch
  4. drhofferber
    drhofferber New Member
    Jun 22, 2008
    307
    where is the white wire from mag...first disconnect the green wire you put on the frame.now see if it starts...
  5. GearNut
    Aug 19, 2009
    5,105
    Disconnect both wires that lead to it, keep the mag to cdi wires connected though.
    Also make sure that the darned sparkplug cap is still attached to the spark plug wire if you are running the stock set up.
    The next cheapest thing is to replace the spark plug with a NGK B6HS or B7HS (gap to .025"), and if that don't work,install a quality spark plug wire. You can use a coil to distributor wire from a car, or any used known good wire that has a 90 degree boot on one end.
  6. oldsurfer
    May 21, 2010
    126
    got it running..sprayed dw40 in the carb and put the choke on....fired right up...question...the motor surges until it gets up to speed is this typical of 2strokes?
  7. Bikeguy Joe
    Jan 8, 2008
    11,529
    It running lean more than likely. Check your plug.
  8. Venice Motor Bikes
    Mar 20, 2008
    6,211
    24
    The NGK B7HS plug is a little too cold... Use a B5HS or B6HS! ;)
