why
Discussion in 'Motorized Bicycle General Discussion' started by bakl12, Nov 9, 2009.
  1. bakl12
    bakl12 New Member
    Jul 25, 2009
    11
    is it that i have to put up my chocke then try to start my engine then put down my chocke so i can ride my bike i have never had this problem before... anyone???:-||
  2. 42blue15
    42blue15 New Member
    Sep 18, 2008
    136
    "Choke", I guess you mean?
    Two things I'd check:
    1) your air filter is getting dirty (will still work for a while, but engine is already not producing full power), or-
    2) junk in your fuel jet.....
  3. Maxvision
    Maxvision New Member
    Jun 13, 2009
    551
    Didja put an inline fuel filter between your carb and gas tank?
  4. bakl12
    bakl12 New Member
    Jul 25, 2009
    11
    i lost the idle screw on the motor and i forgot to cover the whole so im guessing air got into it could that be the probelm
  5. Maxvision
    Jun 13, 2009
    551
    Hrmmm....could be...
    Did the problem start right after you lost it?
    That open hole could be causing your bike to run LEAN. Expect a melted piston in the near future.
  6. bakl12
    bakl12 New Member
    Jul 25, 2009
    11
    well i got a new screw for it but i dont know when the problem started because i lost it when i was still installing the motor so i started running it when i got the new screw should i just buy a new motor
  7. bakl12
    bakl12 New Member
    Jul 25, 2009
    11
    wait why did you mention the filter because i have one between the carb and the tank
  8. bairdco
    Aug 18, 2009
    6,352
    28
    wait. so you just need the choke to start it, and then it warms up right away and you put the choke down and it's fine?
    that's normal.
    i start my bike with the choke up, then depending on how fast it warms up, i put it down and everything's fine. usually 10 to 20 seconds with the choke on works for me.
    that's what a choke does. it's for cold starts.
  9. bakl12
    bakl12 New Member
    Jul 25, 2009
    11
    oh really well this is the first time out of the 8 that ive had that this has happened to me well its good to know im not the only one also saved some money buy not buying a new motor
  10. bairdco
    Aug 18, 2009
    6,352
    28
    if it just takes a few seconds with the choke on to get it running, everything's normal.
    as the weather gets colder, you'll need to use the choke more often to start it.
  11. skjjoe
    skjjoe Member
    Mar 9, 2009
    393
    get a new idle screw before you burn that engine up:-||
  12. Bikeguy Joe
    Jan 8, 2008
    11,529
    Fo'sho'.
