why am i going so slow?
Discussion in 'Motorized Bicycle General Discussion' started by skyhawk217, Apr 7, 2010.
  1. skyhawk217
    skyhawk217 New Member
    Aug 24, 2009
    16
    i cannot seem to break into the 30mph club w any consistency whatsoever. i purchased a 66cc engine kit from Dax, and from there uprgraded the exhaust w an expansion chamber, ive swapped out stock intake for a HP air intake filter, ive put a 36 tooth sprocket on, this new build weighs a fraction of my 1st build (beach cruiser) and i still cannot reach or maintain 30mph w any consistency. cant do it w out wind or downhill either (d'oh!!!). any ideas would be great. -Skyhawk217 aka Moto Rob :-||
    p.s. i live at 700ft elev in central IL
  2. fm2200
    fm2200 New Member
    Nov 16, 2008
    258
    The engine is really not designed for any real torque. If you feel the need for performance just go and get an old motorcycle, there are hundreds of them on craigslist. I know you could get a real nice one at a reasonable price. If it's the challenge of getting the little engine to do more I can understand that too.
  3. stuartracing
    stuartracing New Member
    Dec 9, 2008
    488
    How do you know your not going 30 mph????
    It`s not really that easy to go 30 unless you are more experienced at building motors....Not saying your not, ok....Are you driving next to a car or something to tell how fast your going????I`ve done some pretty good port works and same stuff as you and CAN go 30 if I want to push it....I have a 44t sprocket....Whats your weight like????Plug looks good???? No air leaks????
  4. Charged-Reacter
    Charged-Reacter New Member
    Dec 12, 2008
    286
    It might help to go to a smaller front sprocket. More likely your running
    a 44 t00th front sprocket with your 36 tooth rear sprocket.
  5. Charged-Reacter
    Dec 12, 2008
    286
    Bump that. I do not know what I am thinking about. I have been messing with a 5 horse briggs
    with a cvt off a snowmobile.
  6. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Details:
    What does your spark plug look like? (After running WOT for a few minutes, and a nice clear picture would be great.)
    What fuel mix are you running?
  7. sportscarpat
    sportscarpat Bonneville Bomber the Salt Flat record breaker
    Jun 25, 2009
    1,734
    40
    Align your drive train. I bet your engine sprocket and rear sprocket are not aligned with each other causing a little vibration. Engines tend to torque to the left. Sounds crazy, but take a look.
  8. skyhawk217
    Aug 24, 2009
    16
    the bike weighs 53lbs w 1L fuel. i run 4oz honda hp syn per gallon. i have a speedometer and also ride beside FileStyle and our speedometers read the same. Filestyle and another buddy can both run 37mph all day. my set up is nearly identical to theirs. my plug is pretty clean actually. there is a slightly oily film on bottom side of head (running rich?)
  9. Bikeguy Joe
    Jan 8, 2008
    11,529
    How many miles do you have on it? If it's not broken in and tuned properly, it won't go much more than about 25 mph.
  10. Bikeguy Joe
    Jan 8, 2008
    11,529
    Especially with the 36T.
  11. stuartracing
    Dec 9, 2008
    488
    X2.....
    I just came in from a ride and was thinking of your deal too....
    I hear ya, it should run at least 30 in a good tune....Mine is tuned the best I have ever had one of these tuned and at 30 my bike was going pretty dang fast by what my Bell speedo said, which coulda been 25 or 38 mph....But this is on a $70 cheapo beach cruiser....
    How fast ARE you going???? Whats it doing once it tops out???? What pipe ya running??? Stock carb.??? Air filter??? I`m waiting for my Pipelyne Chamber to get here and then see waassuppp.... Right now it`s making all the power down in the lower rpm`s.... Is your`s just not reving out???
    Hope I`m not buggin ya, just trying to help you get to the bottom of this,ok....
    Keep in touch with us....
  12. skyhawk217
    Aug 24, 2009
    16
    i have about 700M on it. Break in period consisted of 7oz oil to 1g gas, did that for 3 tanks. i treated the engine like training in running (jog then sprint, repeat). cruise nice and easy then open it up for a short distance, then repeat. idk, im thinking of replacing carb and billet and re-looking at the exp chamber i have. i wanna go a 100!!! just kidding, but 30mph club would b great. until i can surpass Filestyle and hit 42-43 for the breifest moment, i cannot rest. haha
  13. stuffandstuff
    stuffandstuff New Member
    Oct 11, 2010
    15
    I know this post is older but I'm not breaking 25 mph but I'm sure is because I only have 40 miles on it and still using 16 :1 mixture...
  14. Bikeguy Joe
    Jan 8, 2008
    11,529
    Yeah, don't do that. (16:1)
    Really.
  15. Vistaman73
    Vistaman73 Chat Box Junkie
    Nov 29, 2009
    247
    ^^^^^^^^^^^Exactly. 32:1 for break in then what you feel is right. I run 32:1 period.
  16. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,433
    What tires are you running?
    big dif between cruiser tires and more narrow...
    I don't think anyone should really run more than 1.75 width if they want to roll-
    unless you're off road or in gravel
    and unless you really can't spend the money to switch- then do it as they wear out.
    When you switch- you'll feel the dif peddling- the effect is even greater for the motor-
