Whizzer motor vs huasheng 49 cc
Discussion in 'Motorized Bicycle General Discussion' started by \./, Apr 4, 2013.
  1. \./
    \./ Member
    Dec 4, 2011
    385
    Can anyone who has used both motors compare and contrast the 2? I understand the whizzer motor is of much better quality, larger size and easier oil change lol, but anything other than that?
  2. Otero
    Otero Member
    Feb 1, 2010
    746
    That's comparing apples to a gooseberry. The whizzer is far
    superior in every respect but fuel consumption. The Hua Sheng
    gets better milage when it's running that is.
  3. azbill
    azbill Active Member
    May 18, 2008
    3,367
    AFAIK, the quality of the whizzer engine depends on when and where it was made
    (usa/old vs taiwan/new)
    even though I don't use it anymore, I never had an issue with my HS ;)
  4. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    I've never had a Whizzer engine, but I know quite a few who've had one. I almost bought a new one in 2010 for my bike, but research dissuaded me.
    Instead, I bought a Huasheng. Since August 2010 I've put ~6K miles on it and have had zero engine mechanical problems. Just a couple gummed carburetors.
    The Whizzer engine has more torque and much more potential horsepower. It's also considerably more expensive. It will likely need work to keep running.
    The Huasheng is cheaper and will tend to be more reliable - it's a utility engine, made to run all day long. Whizzer engines can be very reliable with a bit of work.
  5. Otero
    Otero Member
    Feb 1, 2010
    746
    UH HUH. Can i go to Vegas with you? That's truly " unbelieveable" luck.
  6. The_Aleman
    Jul 31, 2008
    2,658
    Luck? Not at all. I know of at least 2 members here who put over 10K miles on these engines.
    The key things are to know their limits, don't ask for too much, and maintenance. Your experience is not the norm, Otero :rolleyes:
  7. 4stroker
    4stroker New Member
    Apr 7, 2013
    Hi folks I feel the need to weigh in here (no fat jokes please)
    I,m on my second year and 1500 miles with no problems on GS. Double what I was getting on China girls.
    They use a splash oil system so they do not like to be run at max rpm. My bike is geared so that 30 mph is max rpm for the motor so i can cruse at 25 all day long. I also recomend synthetic oil, im using Amsoil 10-30 automotive.
    I have had no starting issues what so ever never more than 2 pulls. I find the carburation to be spot on once the air screw is adjusted correctly after breakin. Oh,,, I am running stock exaust and air cleaner. These after market pipes and cute looking air cleaners require rejetting that most people don't do and I suspect that is the reason for bad running engines.
    Final note, ADJUST THOSE VALVES!
  8. mason_man
    mason_man Member
    Jul 19, 2009
    658
    \./,there has been a lot of myths about whizzer motors, about quality control, i think it's been more about damage control (bad).
    i have the vintage and new edition motors, WC-1's, NE kits, NE-R,i sent out my info back in 2007.
    If you decide whizzer i've got extra parts if you need, just need to swap back what i send you if your happy with it.
    Ray
  9. MotorBicycleRacing
    Jul 28, 2010
    5,690
    30
    "GS" is kinda cryptic?
    Honda GS 160?
    Do you have a pic of your GS?
  10. 4stroker
    4stroker New Member
    Apr 7, 2013
    Sorry about that.
    Early morning typo, GS should have been HS short for huasheng.
    Regards.
  11. \./
    \./ Member
    Dec 4, 2011
    385
    im planning on running a HS 49cc on my btr build, but i also have a '97 whizzer bike (maybe use the engine and transmission off of it?) that i got in a trade. its in rough shape and will need some restoring. it does run, but no more than ~32 mph on flat
    #11 \./, Apr 8, 2013
  12. mason_man
    mason_man Member
    Jul 19, 2009
    658
    My offer still stands, go to the whizzer forum when your ready!
    Also www.whizzerusa.com has lots of stuff for us give them a call, other www.woodstockwhizzer.com has the complete top end, i think.
    Is it the black 26" wheel WC-1? WC-1 stands for Whizzer Classic-1
    I cut my teeth on this one.
    Ray
  13. Highwaystar
    Highwaystar Member
    Jan 22, 2012
    263
    I love my Whizzer. It does everything my other motored bikes couldn't.
  14. mason_man
    mason_man Member
    Jul 19, 2009
    658
    Good to hear that Highwaystar!!
    Ray
  15. \./
    \./ Member
    Dec 4, 2011
    385
    yes its a wc-1
    i decided to keep my whizzer as a criser and restore it later on, i will be using a hua sheng 49 cc on my BTR build.
  16. mason_man
    mason_man Member
    Jul 19, 2009
    658
    YES!!!!!!!!!
    Ray
  17. \./
    \./ Member
    Dec 4, 2011
    385
    as soon as i finish my BTR i will start the whizzer restoration. ill definitely try to make it look more vintage, the guy who had it before me stripped off all the cool lights and gadgets anyway
