where to get double wall 26 in wheels
Discussion in 'Motorized Bicycle General Discussion' started by chainmaker, Apr 21, 2010.
  1. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
    Does anyone have a source for 26 inch wheels, heavy duty,double wall, front w/ disc, & rear disc w/ freewheel
    Thanks & Cheers
    Chainmaker
  2. RedB66
    RedB66 New Member
    Dec 28, 2007
    1,023
  3. AaronF
    AaronF New Member
    Aug 24, 2009
    389
  4. azbill
    azbill Active Member
    May 18, 2008
    3,367
    I have done business with Bike Island before (ebay post above)
    they ship fast and the wheelset I bought was exactly as advertised
  5. bairdco
    Aug 18, 2009
    6,403
    50
    you can order rims and spokes directly from worksman, as well as a whole wheel, but i don't think they have any disc set ups. worksman rims are probably the best out there.
  6. ocscully
    ocscully New Member
    Jan 6, 2008
    373
    I'm curious as to why you think they are the best rim available for a motorized bike? I'm not saying they are or are not. I'm just wondering why you think they are the best?
    ocscully
  7. obd1kenobi
    obd1kenobi New Member
    Dec 28, 2009
    79
  8. 42blue15
    42blue15 New Member
    Sep 18, 2008
    136
    I don't know why he thinks they're the best, but if you get the steel rims, they are rolled-edge which looks very retro,,, but also means you can only use hub-mounted brakes.
    Some rims are stronger than others but rim strength is not much of a concern with any bike used on-road. As I have seen it (with non-motorized bicycles) the first thing to break on very-cheap wheels is usually the spokes, and the second thing is that the cheap wheel bearings fail.
    If you are looking for the widest rims that you can get normal tires on, that would be Snowcats, at right about two inches outside width. These are about the widest rims you can use with a standard MTB tire (with 2.3"-2.5" wide tires). I don't know when it will be, but the next motorized bike I build will use these rims.
    The Surly Large Marge rims are wider at 2.5", but regular MTB tires don't really fit well on them. With the Large Marge rims you are stuck using the 4" tires that Surley and other fatbike places make, usually costing $100-150+ each, and mostly off-road treads.
