where can i get a spark plug for my 49 cc china engine kit in syores?
Discussion in 'Motorized Bicycle General Discussion' started by ajslim420, Jul 22, 2012.
  1. ajslim420
    ajslim420 New Member
    Jul 22, 2012
    12
    Im tired of getting everything online i wanna ride my bike! It wont trt but it seems like it wants to. I want a good spark plug that i can use but not f up everything.:-||
  2. Bernie
    Bernie New Member
    Jun 19, 2012
    48
    Yeah I would like to know this to. Went to 4 different places today and nobody had a plug for me.
    To bad for me that pirate cycles didn't bother to put them in my order after I had paid for them. Nor return any emails about it.
  3. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    NGK BP6HS
    NGK B5HS
    NGK B6HS
    Champion CJ7Y
    AutoLite 5843
  4. Goat Herder
    Apr 28, 2008
    6,251
    I ordered from them on many occasions and would not hesitate to do so again my stuff came quick too. (^)
    These spark plugs do exist locally in many shops.
  5. Goat Herder
    Apr 28, 2008
    6,251
    Oh yeah welcome to the forum ajslim420!
  6. MotorBicycleRacing
    Jul 28, 2010
    5,736
    Be careful recommending a BP6HS as the extended tip may hit in a 50cc
    I know that they work in a 66 cc / "80" straight head.
    I would say stick with NGK B6HS to be on the safe side.
  7. Bernie
    Bernie New Member
    Jun 19, 2012
    48
    I made sure I had the right ngk number b6hs and went back to one place and they had autolite 4093 as a replacement. Am I good to go with that autolite number the other autolite numbers are different posted above?
  8. Bernie
    Bernie New Member
    Jun 19, 2012
    48
    Yeah they are quick and I will order from them again but thought they would of sent me an email in four days since.
    I did go to five different places today and one place twice to get plugs. If I had a new plug then I can get one one thing fixed with my build. Which last time I left it was spewing gas out that plunger so I dont even want to try to start till I get some bugs worked out.
  9. Goat Herder
    Apr 28, 2008
    6,251
  10. mark880088
    mark880088 New Member
    Feb 22, 2010
    111
    Re: where can i get a spark plug for my 49 cc china engine kit in stores?
    I use NGK (3922) BR6HS because i have a speedo. I get them at the local auto parts store. While your at it you should replace the spark plug wire also. I think its 8mm? Search it you'll find a link that tells you how to do it. A good plug and wire make a huge difference. Sometimes the auto parts stores cant find the spark plug under the manufactures number so just use the four digit number.
  11. Bernie
    Bernie New Member
    Jun 19, 2012
    48
    thanks for the chart
    it says it replaces the br6hs and the b7hs but when the guy crossed referenced it at the store we used b6hs. I wouldnt trust their computor to be right for what I want and that is a b6hs.
    So with my limited knowledge about plugs so far I have a plug that will work but might be to hot but could use it till I get the plug I want. Or would it hurt the motor running a hot plug. To be honest I cant remember which way the hot or cold swings.
  12. Goat Herder
    Apr 28, 2008
    6,251
    R is for a resister noise suppression plug. The lower the number is in the title with NGK spark plugs the hotter the plug runs for self cleaning. If you do any thing make sure the plug clears the piston. Turn the motor over once don't start it at first. It should look thread depth wise close to the plug you had.
    #12 Goat Herder, Jul 23, 2012
