Where can I buy a stand alone motor? A 49 cc that with fit this?
Discussion in 'Motorized Bicycle General Discussion' started by athletichunta, Aug 23, 2010.
  1. athletichunta
    athletichunta New Member
    Jul 22, 2010
    114
    #1 athletichunta, Aug 23, 2010
  2. athletichunta
    Jul 22, 2010
    114
    #2 athletichunta, Aug 23, 2010
  3. azbill
    azbill Active Member
    May 18, 2008
    3,367
    the HS engines come with different size shafts (15mm + 5/8"),
    as well as tapered and straight shafts...
    that makes it hard to tell from the pics alone what other engine is compatible with your kit :(
  4. athletichunta
    Jul 22, 2010
    114
    It seems to me if that if the female side i.e. of the gearbox fits into the clutch housing then it should work fine. Maybe I am missing something but I am not sure what shaft size has to do with the compatibility of this clutch with the gear box I have. What say you?
  5. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    I'm pretty sure most motors aren't going to come with the clutch. The clutch is part of the gearbox not the motor.
  6. fritzalee
    fritzalee New Member
    Jul 15, 2008
    13
    athletichunta
    just call bikeengines.com and ask them, looks like a 77mm (3") three shoe clutch to me and the bell on the tranny looks to be the same, couldn't tell you if the ratios are ok.
