Whats that burned rubber smell?
Discussion in 'Motorized Bicycle General Discussion' started by 59Cruiser, Aug 28, 2011.
  1. 59Cruiser
    59Cruiser New Member
    Aug 11, 2011
    36
    Finished my bike today ... runs and rides better than expected. I have a couple minor things to adjust but thats just because I want everything perfect.
    Anyway, when I turn off the motor after riding, I smell burning rubber. Is that normal break in smell or do I have something else going on. It seems to be coming from the engine and not the tire. I figured its the gaskets, exhaust and maybe even chain tensioner breaking in?
  2. archertiger3
    archertiger3 New Member
    Aug 28, 2011
    30
    what's your gas/oil mixture?
  3. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    If it's a black painted engine, it could be that. Our first one was painted black, I had to spray brake cleaner and remove all the black. It smelled when hot and sitting still.
  4. 59Cruiser
    Aug 11, 2011
    36
    The engine is painted .... its painted silver. Came that way.
    My fuel mix is 16:1 per the instructions in the kit. After burn in it says I can run 20:1
    Its definately a burned rubber smell like a tire burnout. The kit I have is one of those chinese deals from eBay
  5. DuctTapedGoat
    DuctTapedGoat Active Member
    Dec 20, 2010
    1,179
    8
    I'd put money on it that you have a black painted exhaust, and that's what you're smelling.
  6. 59Cruiser
    Aug 11, 2011
    36
    Exhaust is chrome although there is black goop coming out of the bottom. I figured it was from the rich gas mix but maybe there'se something else in there?
  7. DuctTapedGoat
    Dec 20, 2010
    1,179
    8
    My first though would be that you're prolly just running rich - but pull the exhaust off and remove the end cap just to be sure. Ya never know what could have slipped past chinese quality assurance...
  8. WildAlaskan
    WildAlaskan New Member
    Sep 30, 2010
    581
    if yer runnin 2 stroke mixe try 24 to 1 then 32 to 1 after break in the 16 to 1 is for 30 weight oil used in china
  9. 2door
    2door Moderator
    Staff Member
    16,310
    Clutch pads wearing in. Don't worry about it.
  10. DuctTapedGoat
    Dec 20, 2010
    1,179
    8
    2door, you rock. Didn't even consider the clutch pucks.
  11. 59Cruiser
    Aug 11, 2011
    36
    ah ha ... yes, thats where its coming from ... so pretty much normal break in you think? I am trying to take it easy on the clutch but it definately gets its use. It takes a little time to get used to giving it the right amount of gas when letting the clutch out after slow downs and turns.
    I can't wait to break this engine in and really see what it can do. The bike is surprisingly, almost a little scary, faster then I expected with much more torque than I thought it would have!
  12. 577-Jersey
    577-Jersey New Member
    Mar 23, 2013
    293
    Just wanted to add mine does the same thing,,
    The Chinese use rubber instead of a copper resin/asbestos type.If you trim the pads up before use and make em all the same size this will reduce the smell,,the reason they do this is because some pads contact the plate more than others is what I am seeing.
  13. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    When I used to have a 2 stroke, I would smell burning plastic sometimes while driving. I never did figure out what it was, even pulled over a few times to check the bike over. Checked my tires, wheels, wiring, everything, never found anything.Maybe it was my clutch pads wearing in as well. Anyway, if you ever smell or hear something odd, check the bike over. If you cant find anything wrong, there might not be anything wrong. If its a noise from the engine, might want to check a little further, maybe inside the engine.
  14. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
    Those were my exact thoughts when I was breaking mine in.
    It only gets better!
    I remember travelling up the side of a road one day on tank #2 thinking, Holy Crap!
    When people ask how fast it goes, I say, "Too fast for a bicycle!"
