What material is the engine made of?
Discussion in 'Motorized Bicycle General Discussion' started by zobraman33, Jun 12, 2012.
  1. zobraman33
    zobraman33 New Member
    Feb 22, 2010
    6
    I've had a question for a long time which simply is What material is the engine made out of?? I'm sure its not aluminum since aluminum don't attract magnets and its not iron..Iron is very heavy.. So what do you guys think??
  2. moonerdizzle
    moonerdizzle New Member
    Jun 28, 2009
    874
    its aluminum, but its cheap poor grade castings. ive been trying to find out exactly what it is so i know the proper anodizing process to use on the case and head at work.
  3. moonerdizzle
    Jun 28, 2009
    874
    iron and steel can not be combined with aluminum in any real amount. its probobly 3031 or some comparable grade cast aluminum. ive seen castings made from 6061-t6 aluminum have the same feel and apperience as our motors. you cant get a smooth surface with a casting very well
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    Never tried a magnet on any of mine...however, they are aluminum with a nikasil liner, so maybe that's why you can get a magnet to stick to it.
    Also, the crank and other various bits are steel, so the magnet may stick to them for that reason as well.
  5. zobraman33
    Feb 22, 2010
    6
    Thank you guys for your help...and i placed the magnet at the head not near anything metal..So from what you're saying its aluminum mixed with something else :)
  6. multipaul
    multipaul New Member
    Mar 31, 2012
    75
    The cheapest and most used aluminum alloy contains 88% Al and 12% Si (Silizium). The Silizium is rather cheap and saves a lot of energy and time, because it reduces the melting point significantly.
    Cu and Mg can be added. But I doubt. A spectral analysis would be fine.
    Multipaul
  7. multipaul
    Mar 31, 2012
    75
    I've just tried it out. Your bolts and nuts are made of steel. They are magnetic as well as the piston rings. The hard chrome isn't magnetic. The body of the cylinder also not.
    Mulitpaul
  8. Bikeguy Joe
    Jan 8, 2008
    11,529
    Yes, studs, nut's, washers, wristpin, rings, bearings, gears clutch bits, plug.....all magnetic.
  9. Mozenrath
    Mozenrath New Member
    Jan 13, 2011
    340
    It's pot metal. While the majority of it is aluminum, there could be literally any amount of other metals in there! Whatever they want to recycle probably gets chucked in.
  10. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,495
    50
  11. azbill
    azbill Active Member
    May 18, 2008
    3,367
    I tell people the nuts n bolts are 'chinesium' ;)
    all the scrap that was swept off the floor and dumped into the melting pot !!! laff
