What kind of bike is this????
Discussion in 'Motorized Bicycle General Discussion' started by fall_down_stand_up, Oct 18, 2009.
  1. fall_down_stand_up
    fall_down_stand_up New Member
    Apr 26, 2009
    555
    I bought it about 5 years ago at a second hand store and only rode it a coupe of times....It has no markings of what kind of bike it is....down by the back sprocket on the frame there is a serial # of some sort....
    It is a very old bike and I was thinking about putting a springer fork on the front and put a heavy duty rim on the back and then mount a motor....What can I use to get the rust off the chrome????
    p.s the basket was put on by one of my kids from an old huffy bike....That will be gone....
    John-John
      File size:
      71 KB
      54
      File size:
      68.9 KB
      49
      File size:
      74.8 KB
      61
      File size:
      68.8 KB
      75
      File size:
      73.3 KB
      49
  2. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Dunno John-John. Funky lookin'. Gona make a cool MB. Springers will really add to the looks.
    I, in a pinch have used grease to polish chrome. Worked better then Brasso and was easier. Took all the surface rust right off with very lil work.
  3. Salty Gator
    Salty Gator New Member
    Aug 3, 2009
    672
    I've NO idea what kinda bike that is ....but it IS awesome !....I think it would make a cool build!
    As far as removing rust from chrome I'd not bother....just strip it and paint or have it re-chromed.....
    Laters,
    Salty.shft.
  4. treyverb
    treyverb New Member
    Oct 13, 2009
    14
    - that's a nice bike . Go to true value hardware and buy a small can of Oxallic Acid ( Wood Bleach ) . It comes in crystals . Use a giant container or barrel ( plastic will be fine ) big enough to emerge the frame . Fill the container with water add the OA ( about half of the contents will do ) . Leave it over night ( 6-12 HOURS or longer depending on condition of parts ) , come back the next day . Rinse the frame and parts with water , then immediately spray WD-40 on them and wipe down . You can use Mother's or the like to complete the Job with a good polish . I built a lot of os BMX bikes last year and it really helped that hobby tremendously . It made me never look at rusty bike and think " what's the point " .. Be carefull , wear gloves , it is acid . Way Way better than steel wool or any other abrasives . I hope this helps . again very cool bike !
  5. fall_down_stand_up
    Apr 26, 2009
    555
    Thanks for the great respones....I think it looks cool to and you guys have now convinced me to build it into a MB....I have 2 new Raw motor kits coming in the mail this week and will have to order a springer fork and a 2.125 12 gauge spoke rim for the rear and start the build....
    Is there another way to get the rust off other than having to dip it in a 55 gallon drum????I dont have one laying around....
    When I bought the bike it had next to no rust on the chrome frame,but it ended up in the back yard with a bunch of other bikes for a # of years....
    Dan,send me a link to were I can buy the bent seat post like you have on your bike.... Thanks
    John-John.shft.
  6. treyverb
    treyverb New Member
    Oct 13, 2009
    14
    I bought one of those rubber maid containers at wal-mart for $10 ( the biggest I could fine. I dipped a 26 " frame in there . I had to submerge one side and then the other and it worked fine . It came out nice .
  7. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Tom (2 Door) made that bent seat post out of a solid piece. Thing is awesome! Really, really makes for a better ride. I can not recommend them enough. The only other place I know for sure that has them is Spooky Tooth Cycles - Motorized Bicycles: Gas Powered and Electric Bikes - Seat Posts
    Truly, well worth the $. I wan't to make one with some sort of spring.
    The acid wash idea sounds cool Trey. Have any pics of a bike after doing that?
  8. bandito
    bandito New Member
    May 22, 2009
    783
    With those top tubes the way they are its just begging for a in frame gas tank, the slope is perfect too for draining it. Would a drill with a wire wheel remove the rust without taking the chrome with it?...whats up with the rear dropout on the right side it looks different? I dont see an axle nut, might just be me.
  9. treyverb
    treyverb New Member
    Oct 13, 2009
    14
    Look on the bay too for layback seat post or laid back seat post under BMX , while some are super collectible and expensive others are not . Here's a pic of a bike I did after dipping in OA - I really wish , I had the before pics . [​IMG]
  10. treyverb
    treyverb New Member
    Oct 13, 2009
    14
    Unfortunately you would sacrifice the chrome quite a bit . The thing with the Oxallic Acid if that it doesn't require anything abrasive , if the rust is really thick and hated you may need to use a toothbrush to scrub a bit while it's in the bath .
  11. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    very cool Trey, thanks. Looks perfect
  12. treyverb
    treyverb New Member
    Oct 13, 2009
    14
    I forgot to mention that the OA does not destroy your decals on your frame either . It really is a wonder product if you are restoring vintage bikes . sorry I'll be quiet about it now . LOL
  13. fall_down_stand_up
    Apr 26, 2009
    555
    Its just a fuzzy pic the axle nut is there....
    Here is a close up pic of it.....I wish I could weld,I would love to have a inframe tank....
      File size:
      78.2 KB
      34
  14. bandito
    bandito New Member
    May 22, 2009
    783
    Thanks fall down I see it now from the other pic I couldnt see the axle and nut.
  15. fall_down_stand_up
    Apr 26, 2009
    555
    This is what I will have to put into the bike to have it ready for a engine kit....
    40.00 heavy duty 2.125 12 gauge spoke rim for rear with coaster break(factory rim is wasted)
    50.00 for tires and tubes
    49.00 for chrome springer fork
    25.00 for chrome remover and wal-mart rubber tank to put the remover in
    40.00 for chrome double hanger fenders
    10.00 for new chain
    224.00 total
    Thats now including all the bells and wistles,such as speeomoter,headlight,tail light,bent seat post,etc....
    Its a very cool looking bike,but would you put that kind of money into it????I know it will be nice when im done,but undecided after looking at all the stuff I need to buy....
    John-John
  16. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    No! that is great to know and thanks for sharing. I have at least 6 bikes in need of just that
    John-John, was thinking the same thing as Bandito. Would be awesome to have an in frame tank. Could make a cardboard one and buy a piece of aluminum plate. Bring it to a welder shop. Ride an MB there. I find folks like welders and machinists get almost as excited as me about these things and come up with awesome ideas and thoughts. That and the seem to really enjoy taking part in our crazy and charge very lil as they are having fun with it. Could put a site glass on the side using a pet cock and an "L" shaped fitting. A brass candy can shaped tube as a vent .....
    LOL, I need help. Sat here all day and window shopped, wish listed about 2K$. (I wanna do exactly what I just said for a Point beach build)
  17. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Dunno John-John. Yesterday I had decided to focus on making just one awesome MB. Today, I saw at least 3 concepts here I want to build. Is a sad yet so very fun addiction. So, I really dunno if it would be worth it to you. Could build it with the thought of selling. I have never had much luck with that though. Not that they don't sell, they do. More just the fact that a monkey can't sell bananas.
    on a MP 2009 Felt MP
    And came up with a way to not use a GB on a 4 banger, LOL!
    forgive the rambling. Just sayin' it is kinda like asking the drunk on the next barstool if we drink to much.
    So I vote; Build it!
    (and of course, strongly advise you to completely ignore any and all of my advise)
  18. fall_down_stand_up
    Apr 26, 2009
    555
    Im going to have to think this over....I l love the felt MP cruiser,been wanting one of those for a long time....If I build this bike I will not sell it unless I was offered alot....I want to have 2 bikes at all times so I have a back up incase one breaks down....
    John-John
  19. Salty Gator
    Aug 3, 2009
    672
    Yes John I'd do it......you'll have a *one-off* bike that no one else on the planet will have....$224.00.....alot of people spend WAY more'n that.....your bike will be unique.....and you will be answering questions about until you die......PRICELESS !
    Laters,
    Salty.shft.
  20. bairdco
    Aug 18, 2009
    6,376
    37
    it's a Spaceliner. dunno what year, but they were available in the 50's and 60's.
    yours could be a J.C Higgens or a Sears, depending on the year.
    same bike, just different company names.
    here's a link:
    http://www.trfindley.com/pgspclnr.html
