what is the best motor available?
Discussion in 'Motorized Bicycle General Discussion' started by apop526, May 10, 2011.
  1. apop526
    apop526 New Member
    May 7, 2011
    Please help!
  2. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,819
    11
    This is the toughest question to answer because it depends on a lot of things.
    A Morini motor is considered by many to be the best, but will not simply bolt on. If you are not a welder, it's not the best motor for you.
    The latest SpookyTooth death race was won by an electric bike (Yes, it beat two Morinis), so you cannot rule them out if you can afford it.
    Tanakas are powerful if you want a rear rack mounted motor.
    If you just want more speed, a china girl motor with an expansion chamber exhaust and shift/jackshaft kit may work best.
    It just depends. Keep reading the forums to see what works for you.
  3. ducedave
    ducedave Member
    Apr 17, 2011
    375
    7
    I'm happy 66 cc. RAW brand China motor ALL THE PARTS IN THE KIT S--K but the motor is well made
  4. apop526
    apop526 New Member
    May 7, 2011
    Thanks for the info. I'M looking into some grubee motors. JUst not sure which one. I like most others want speed torque and reliability. Any grubee suggestions anyone?
  5. robert cagle
    robert cagle New Member
    Mar 9, 2011
    I just put a grubee on my beach cruzer 26 inch.
    As I read the forum I began to prep the engine
    as soon as it arrived. I removed the top head
    and use indian head shallack on all the head gaskets
    then reassembled with new bolts, not the acorn bolts
    and I tourqerd em down.
    my clutch was very very tight, so I had to adjust the
    clutch spring. look for the instructions in the forum.
    now Im fine tunning the carb.
    This is all a hassle---- but you best be prepared if you
    get a china grubee. they are poorly manufactured.
    thats why there so chep. you can make em run but
    you gott tune em up and in.
    Frankly if I had to do it over I would have choosen the 99 cc from
    harbor freight. 1 yr. guarantee, pull start, 4 stroke.
    I'm using my ride to go to and from work, I want dependability
    At this point I feel that I will be constantly messing with this
    little engine, something I did not want to do.
    In the weeks to come I'll probably get the 99 cc, and fabricate
    motor mounts and have a weilding shop weild it on.
    much more dependable, start and go.
    hope this helped, ps. many riders have not had the same experience
    I had with my grubee, and then many have. If you don't mind constant
    tinkering with ur moto, the grubee is the way to go.
  6. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,909
    82
    The first thing I did was check the DMV web site here in GA. and found out that a 48cc was the largest engine I could use that would not require ins. and a tag.
  7. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    Best motor available? I wouldn't even consider a Chinese 2-stroke. They're like playing the lottery. Usually you don't win.
    I'd be looking at 4-strokes and then try to figure out which one is best :D
  8. chrisc
    chrisc New Member
    Mar 26, 2012
    13
    Hi, just came accross ur post n was wonderin how easy that would be to mount the 4 stroke 99cc on a bike? I looked at thw sit and saw the motor, one the side with the shaft looks like there is something missing. How would you hoow the sprocket up and would else might I need. Thx chris.
  9. thegnu
    thegnu New Member
    Sep 15, 2011
    982
    electric bikes = 100 % tourque at 0 rpm . I watched a you tube vid of a kid smoking motorcycles in grand style with one of them .
    But back to your question best advice is pick a motor kit that best suits your needs an terain .
    Gary.trk
  10. Lance Portnoff
    Lance Portnoff New Member
    Mar 22, 2010
    351
    4 stroke honda or subaru only
  11. BeaverRat
    BeaverRat New Member
    Jun 27, 2011
    147
    Most Cost effective:power = 99cc predator engine.
  12. kla63
    kla63 New Member
    Jul 15, 2009
    111
    who has the best deal on buying bulk of 5 or ten 66 cc two stroke please!!!!
    looking to buy 5 t0 10 66cc two stroke motor kit who has the best deals !!!! kit must contain good up grades !!! and have the 415 chain!.flg.
  13. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    My personal choice is a four stroke.
  14. Greg58
    May 1, 2011
    2,909
    82
    I bought five 48cc grubee engines from Bikeberry last spring, all are still running well, you can call any of the sponsors on the sides of this forum to see who has them in stock. Good luck, Greg
    #14 Greg58, Apr 2, 2012
  15. happyvalley
    happyvalley New Member
    Jul 24, 2008
    786
    ^^Legal in most cases, too.
  16. bairdco
    Aug 18, 2009
    6,352
    28
    i wouldn't recommend the grubee skyhawk kits to anyone. sadly, they're the only ones currently legal to import from china. everyone i've built had problems. blown head gaskets, bad magnetos, weak pistons.
    something as simple as a ring keeper on the piston can break loose and destroy your motor. i was trying to make them faster and more reliable and offer them for sale, but instead, i'm in the hole with a pile of scrap aluminum.
    grubee's poor quality has totally turned me off of the chinese 2 stroke. in fact, i need to rebuild my race motor for the 4th or 5th time, and the bike's got less then 100 miles on it. every engine failure was caused by crappy pistons.
    part of the fault is i'm modifying them to go much faster than stock and the pistons just can't take it. but people have been modifying little engines for 100 years with good results. it's sad when you can't even build the kit straight outta the box without something failing right away. add a little more power and watch all your hours of hard work explode on your way home from 7/11.
    reliability from a chinese two stroke? good luck. making money selling them? good luck. fixing bikes you've built to try to keep a customer happy? get used to it.
    bitter? yeah, a little...:)
