What is different about painting plastic
Discussion in 'Motorized Bicycle Welding, Fabrication and Paintin' started by sofasurferlinux, Jun 8, 2011.
  1. sofasurferlinux
    sofasurferlinux New Member
    Jun 24, 2009
    122
    I have a moped with plastic fenders. The fenders are not a brittle plastic but are quite flexible. What is the process for painting them?
    I know there are spray paints available for plastic, but if I wanted to use custom paint what is required? Additives? Special primer or bonder?
    I'd appreciate your input but also if there is a good website.
    Thanks.
  2. MotoMagz
    MotoMagz Active Member
    Aug 2, 2010
    1,274
    I wipe down the plastic with thinner. Then use one very light coat of plastic primer paint..like rustoleum.Then you can top coat it with what you want.Always do a sample just to make sure.
  3. DaveC
    DaveC Member
    Jul 14, 2010
    970
    There's a product called Plasticoat. Nothing works better on plastics than this paint I have found.
    One piece of advice, use the same paint system for all the coats you put on. It vastly lowers the chance of orange peel, cracks and other related painting problems.
  4. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    Krylon fusion requires no painting or priming. I recently used it to repaint a tire, and it worked great. It is made for plastic, but probably works on other flexible materials. I know I painted my tire off the bike and reinflated it after painting, and the paint didn't crack or flake.
