What gas is best?
Discussion in 'Motorized Bicycle General Discussion' started by danceswithwings, Jun 30, 2010.
  1. danceswithwings
    danceswithwings New Member
    Jun 2, 2010
    6
    For these chinese 2 strokes, what is best, Regular gas or hi octane?
  2. Venice Motor Bikes
    Mar 20, 2008
    6,176
    These 2-stroke engines only have 6:1 compression, so technically you only need 87 octane; But I've found that my bikes run a little better (barely noticable) with the good stuff. Maybe it's the other chemicals they put in the good stuff??
  3. taddthewadd
    taddthewadd New Member
    Mar 1, 2009
    339
    Venice is right about only needing 87 due to low compression and if he notices a difference with the higher octane due to other chemicals then why not go for it. I say this because with the minimal amount of gas these things use we are talking pennies right?
  4. N8dogg
    N8dogg New Member
    Apr 25, 2010
    47
    I figure you might aswell spend 30 cents more for a gallon of premium when you are getting 100+ miles a gallon
  5. bairdco
    Aug 18, 2009
    6,353
    28
    i run premium. i've proven it to myself that it works better for my engines, and like they said above, it's not much money when 2 gallons lasts you a month...
  6. 5446
    5446 New Member
    Jun 7, 2010
    84
    Would you guys use premium during break in?
  7. Salty Gator
    Salty Gator New Member
    Aug 3, 2009
    672
    The higher the octane rating...the hotter it burns....these little air cooled motors run hot anyway....I'd go with 87....my nickels worth.......
    Salty.shft.
  8. nidyanazo
    nidyanazo New Member
    May 25, 2010
    316
    No, the higher the octane rating the more resistance to detonation. It will burn slower than a low octane fuel.
    With a low compression engine 10:1 or less, you are wasting money, and losing power.
    Running hi-test fuel in a low comp motor will lead to excessive carbon deposits, reducing performance.
    Use a premium BRAND (shell, mobile, chevron) and 87.
  9. bairdco
    Aug 18, 2009
    6,353
    28
    or, try them all and see if you can tell which one works best for you. if you can't notice a difference, stick with whatever's cheapest. if you do notice one seems to work better, stick with that, even if it's just your imagination.
    it's not like you're going to hurt anything, i mean, not really. it's not a car, it's an oil burning dinosaur designed to run on 1950's gas and motor oil.
    and no, premium won't hurt during break in.
  10. taddthewadd
    Mar 1, 2009
    339
    Yeah bairdco I bet its the imagination! I can't see how the difference in the gasolines can be noticeable. At least in power.
  11. TYFOON
    TYFOON New Member
    Jun 15, 2010
    10
    What about ethanol mixed fuel? I think I'm going with premium here in Oregon because it's the only fuel I can by without ethanol. What do you think.
  12. ferball
    ferball New Member
    Apr 8, 2010
    599
    I used to run high octane in my old VW bus because I thought it was better for it, then one day quite by accident I put 87 octane poo gas in it, and it ran a hundred times better. I am not saying these two strokes are superior german engineering like my bus, but I have subscribed to the cheap engine cheap gas theory.
  13. Tad Bit Tipsy
    Tad Bit Tipsy New Member
    Jan 2, 2010
    478
    Air cooled engines run better with a lower octane fuel. Even the old biplanes we used to fly in Arkansas(crop dusting) used only 87/88 octane. If your putting higher octane in you engine your wasting you time, no matter what anyone else says on this forum. Any airplane mechanic that works on air-cooled engines will tell you that. Some people think that just because you stick a CNS carb and an expansion chamber on your 2-stroke, that all of a sudden its a high performance engine, bull hockey. its still a minimal HP engine, its still has no fuel injector system to handle high octane fuel, therefore you've wasted your money putting a high octane fuel. Two Cents.
    P.S. good oil makes for a cleaner engine, also use a little castor(1oz per gallon) and you'll be putting down the road a lot happier, put your money into a good synthetic oil, not gas.
  14. TYFOON
    TYFOON New Member
    Jun 15, 2010
    10
  15. Bikeguy Joe
    Jan 8, 2008
    11,529
    Depends on the amount of ethanol. any alcohol will make the engine run leaner. Check your plug or just buy the premium.
    It (premium) will not increase power on it's own, however.
  16. TYFOON
    TYFOON New Member
    Jun 15, 2010
    10
    In oregon it's 10% in all grades but most stations have the option of Efree but only in 92 octane.
    I was going to run the Efree, should I not?
  17. bairdco
    Aug 18, 2009
    6,353
    28
    i'm assuming Efree means no ethanol? if so, 92 won't hurt it. i think these engines would run on dirt, if you could get it to burn.:)
  18. Salty Gator
    Aug 3, 2009
    672
    Gosh.....this can't be stated any plainer than what "The Baird " just said....I've used 'em all......down here in Florida the lowest grade is 87....highest is 93.....not a dang bit of difference performance wise.....what you really need to pay attention to is the OIL you use.....synthetics....semi synthetics....natural......always use a high grade of oil....I've found that Pennzoil works the best in my bikes....but that's just me.....you have to remember these engines are true low tech....the Chinese have yet to offer us anything above that.....I'm just sayin'............................
    Salty.shft.
  19. nolan_speed
    nolan_speed New Member
    May 31, 2010
    30
    Ethanol is really bad news for two strokes. The worst case is in outboards where they're in the moist marine air and the ethanol absorbs all the moisture in the air and it really makes two strokes run like crap and corrode, especially when stored for longer periods.
    The main problem is that you never really know what gas has ethanol and what doesn't until you test for it. Most gas pumps say that they contain up to 10% ethanol, but that doesn't mean that it actually has any in it. Fortunately it's easy enough to test for with a test tube or a Tupperware and you can google how to do it.
    These engines only need regular low octane to run well, however, if premium is guaranteed to be ethanol free, go for it. Don't assume that premium is ethanol free however unless it is specifically stated so.
    I also would disagree with Tad Bit Tipsy about air cooled engines liking lower octane fuel. Many of the air cooled aircraft engines are low compression and do run better on 80/87 octane (not 87/88, that isn't an avgas rating) and there will be increased carbon deposits and plug fouling with the 100LL. There are, however, some higher compression aircraft engines or turbocharged engines (continental TSIO 520 for example) that do require the high octane. It's more about the compression and less about the cooling method.
  20. skyhawk217
    skyhawk217 New Member
    Aug 24, 2009
    16
    i started out using normal 87 octane gas from the local cheap gas station chain here in town and using Honda H2 syn oil. it was ok and probably sufficient. however, i got a wild hair and started mixing half gallon 87 w half gallon 93 (premium) and h2; and my engine runs better and faster and probably hotter too; tho piston' cylinder and spark plug looks beautiful. no excess of carbon and its not too dry and messed up either. im a convert and not going back to straight 87 mix anymore, save for emergencies on long rides or the like.xct2
