What dosent suck on these bikes??
Discussion in 'Motorized Bicycle General Discussion' started by 31ccchopper, Dec 29, 2009.
  1. 31ccchopper
    31ccchopper New Member
    Nov 7, 2009
    15
    i broke my motor studs 4 times already the carberator broke off the intake, the clutch slipp and i cleaned it like 4 times already and adjusted it too.
    Finally i up upgraded to 5/16 americian threads in the engine 3 times bigger. I driled out 3 holes and used a 5/16 tap and wohalli.
  2. bairdco
    Aug 18, 2009
    6,352
    28
    the only thing i really think sucks on these bikes is when my pants leg gets caught on the clutch rod acorn when i'm trying to pedal away from a light, and i almost fall over...
  3. foureasy
    foureasy New Member
    Jul 9, 2009
    478
    the price.
  4. 31ccchopper
    Nov 7, 2009
    15
  5. christopher fowler
    christopher fowler New Member
    Dec 17, 2009
    105
    how many stock fuel filters have broken and sprayed fuel all over rider this sux!
  6. foureasy
    foureasy New Member
    Jul 9, 2009
    478
    i'll sell you stock tanks all day for 35 shipped.
  7. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,433
    Generally, the riders. But they have to speak for themselves!
    LOL!
  8. Venice Motor Bikes
    Mar 20, 2008
    6,174
    When a bike has that many problems; I start to think it's the builders fault, not the bikes! :rolleyes:
  9. freewheeling frank
    freewheeling frank New Member
    Mar 10, 2009
    440
    i ride on dirt roads all the time and other than upgrading to grade 8 bolts and studs no real problems
  10. marts1
    marts1 New Member
    Sep 18, 2009
    392
    I'm already very much looking forward to a better season mostly so I can ride my trusty steed again..duh.
  11. Retmachinist
    Retmachinist New Member
    Oct 21, 2008
    637
    I have to agree with Norm (Venice Boy) When you consistantly have alot of problems I would look into the way things are installed and the amount of torque you are putting on the bolts. I am building my 12th bike now and have ridden a couple thousand miles on several different bikes with very few problems. Most people brag about how fast they can put one of these together and that is probably what gets them in trouble. Just MY opinion.
    John
  12. john_the_great
    john_the_great New Member
    Oct 24, 2009
    191
    I understand breaking the motor studs, there weak. But how in the world did ya manage to break the intake? Or get your clutch to slip, are ya running it without a cover, or over-grease it? And are you using an air filter/fuel filter?
  13. Outrunner
    Outrunner New Member
    Dec 27, 2008
    147
    I used to own a motorcycle repair and racing shop in Detroit. After over 18 years
    of working on customers motorcycles I came to realize that their are many
    people that just cannot comprehend the principle of over-tightening bolts, nuts,
    studs, allen-head screws, etc, etc.. We had to remove cylinder heads and install
    spark plug thread inserts on dozens of engines to repair stripped out spark plug threads, due to over-tightening. Plus stripped out aluminum engine cases,or replace broken studs, it is mind boggling how often that occurs. Most of the bike
    owners would blame the manufacturer or not admit that they were really the cause of the breakage, but I firmly believe that a cheap Harbor Freight torque wrench could be an invaluable asset to most inexperienced "mechanics". It seems like there is no understanding of the difference between tightening a lug nut on a car tire to tightening a 1/4" bolt in an aluminum case! Go figure!!
  14. Gareth
    Gareth New Member
    Dec 8, 2009
    125
    Quoted for truth. I used to be partners in a VW restoration shop. The bad thing about VW's is they are deceptively simple to service, so everyone thinks they are capable of doing so. Many are not. =-)
    A pet peeve of mine is how few things in life seem to come with proper torque values listed any more. I know there are standards I can look up, and really I am a pretty damn good estimator after years of practice...but with the info more available maybe just maybe a few less experienced persons might think it important enough to follow.
  15. john_the_great
    Oct 24, 2009
    191
    torque specs with these kits would be ideal. The mounting studs of the two-strokes, you don't have to reef on 'em that hard because they come with lock washers. The way I snapped my studs twice was killin' the motor by slowly slipped the clutch with the brake pulled in. I finally got outta that habit and now I kill it with the choke.(I'll splice my wires eventually) btw has anyone succefully grounded the kill switch? What did you connect it to?
  16. Gareth
    Gareth New Member
    Dec 8, 2009
    125
    I Just run the black wire to my right side engine mount stud and secure it with a second nut. It is nice and clean and grounding right to the case.
  17. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    I've got my kill switch wired to the white wire, and grounded to the u-bolt on my custom plate front motor mount. Sometimes it works great, sometimes I have to hold and wiggle the switch.
  18. Evan
    Evan New Member
    Dec 6, 2009
    103
    I upgraded all the studs first thing and have yet to snap or break anything (fingers crossed) Either your luck is real bad or mine real good.
    Evandnut
  19. Venice Motor Bikes
    Mar 20, 2008
    6,174
    When torquing the bolts on these HT kits I don't use a torque wrench... I recommend a 'firm snug' on the bolts, & after a few days of riding, I re-snug 'em! ;)
  20. Outrunner
    Dec 27, 2008
    147
    I also do the same as you do Venice, only because we have the "feel" for
    what the difference is between firmly snug, too tight, too lose or whatever. That
    ability is really acquired through experience or training I believe.
