What does this spark plug tell you?
Discussion in 'Motorized Bicycle General Discussion' started by tudorvintiloiu, May 12, 2010.
  1. tudorvintiloiu
    tudorvintiloiu New Member
    Apr 19, 2010
    41
    Sorry I have to do this, but I just don't know how to "read" the way a spark plug looks.
    So waht do you think? Do I need to adjust anything?
    Thanks,
    Tudor
    [​IMG]
  2. professor
    professor New Member
    Oct 14, 2009
    501
    You are running rich. The adjustment would be in the carb.
  3. tudorvintiloiu
    Apr 19, 2010
    41
    Thanks for the tip. My needle clip is set second from the top. I could raise it to the first position, but i'm still during my break-in period. Should I do it now, or should I wait a while?
  4. city of angels
    city of angels New Member
    May 24, 2009
    470
    i will wait since you are on your breaking period what oil are u using like mine i am running 50:1 for my breaking and now i am running 100:1 i am using amsoil oil i was having the same problem but once i switch everything is fine now hopefully this helps
  5. tudorvintiloiu
    Apr 19, 2010
    41
    I'm running 20:1 non-synthetic regular cheap oil. I will switch to synthetic oil and a much leaner oil-fuel ratio after a few gas-tanks.
    I've heard this is best for a new engine.
  6. motorking
    motorking New Member
    May 13, 2010
    Hi,
    I am the tech manager at Autolite spark plugs. Your plug actually looks very good for now. I would completely break it in. Then do a WOT run, chop the throttle closed and shut it off. Then you can really "read" the plug.
  7. tudorvintiloiu
    Apr 19, 2010
    41
    Thanks motorking! Much appreciated! :)
  8. Fabian
    Fabian New Member
    Sep 9, 2009
    168
    tudorvintiloiu
    You haven't provided enough information about the running conditions of the engine and the type of fuel used and the oil/fuel ratio.
    Was that plug pulled from the engine after light throttle use, or after idling for some time, or coasting downhill or wide open throttle?
    Mixture analysis cannot be determined unless all these factors are known.
    Fabian
  9. tudorvintiloiu
    Apr 19, 2010
    41
    20:1 oil-fuel because i'm breaking it in. The plug was pulled after a normal (flat) 6 mile run and after the engine cooled off.
    Thanks,
    T
  10. Fabian
    Fabian New Member
    Sep 9, 2009
    168
    what percentage of throttle were you using for your 6 mile run?
    What fuel were you using?
    What was the air temperature at the time?
    What was the level of humidity at the time?
    What was your altitude at the time of the run?
  11. Fabian
    Fabian New Member
    Sep 9, 2009
    168
    and if you know it, what was your cylinder head temperature at the time?
  12. tudorvintiloiu
    Apr 19, 2010
    41
    Oh, come on! I may not know that much about these engines, but I know it's not rocket science. ALL this might be relevant for competition motorcycles, but i just wanted to know if the way my plug looks means i'm too rich either on oil or fuel.
    Thanks anyway,
    T.
  13. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    yeppers ;)
    I agree completely (^)
  14. good vibrations
    good vibrations New Member
    Mar 30, 2010
    70
    Really guys, he was probly lookin' for a yes or no. Look great right now. Run another tank or two that way and you should be good to go. But even after, DON'T SKIMP ON THE OIL. Lifeblood man, LIFEBLOOD=)
