what does he mean?
Discussion in 'Motorized Bicycle General Discussion' started by Juhstun, May 18, 2012.
  1. Juhstun
    Juhstun New Member
    May 17, 2012
    21
    so my bm messed up on me today and i asked for help but didnt quite understand what he meant?
    gas was leaking from the carb and he told me:
    Your float stuck and you flooded the engine.
    Make sure to turn off the gas when you take a nap.
    To fix it, turn off the gas, and pedal it around with the clutch out, and it should start. Don't use the choke, and hold the throttle wide open to expedite the process.
    what does the clutch out mean? holding onto the clutch?
    and by not using the choke, does that mean the small hole should be on for the choke?
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    He means pedal the bike with the clutch engaged, and don't apply the choke, which will just exacerbate the problem. He also said hold the throttle wide open to help clear out the built up gas.;)
  3. Juhstun
    Juhstun New Member
    May 17, 2012
    21
    so do i leave the choke on the big hole or the very small hole?
  4. superharry
    superharry New Member
    Mar 10, 2012
    129
    "to choke something, what do you do?" make the hole smaller. BIG HOLE= CHOKE OFF. LITTLE HOLE= CHOKE ON. Now go pedal with the engine engaged,like you're starting it,with the throttle opened all the way (floored). have fun & drink plenty of fluids...
  5. Bikeguy Joe
    Jan 8, 2008
    11,529
    Open it....I guess that would be the big hole. You want as much air as possible to go through the engine to dry it out a bit.
  6. Juhstun
    Juhstun New Member
    May 17, 2012
    21
    thanks for the help guys! will test it out ina bit
