Well crud....
Discussion in 'Motorized Bicycle General Discussion' started by Finfan, Mar 23, 2009.
  1. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    I bought a 56 tooth sprocket from Dax. I am not a speed demon by any stretch of the imagination so I thought it would be nice to have the low end torque. However the sprocket has the plane of the teeth slightly offset from the plane of the center. With the offset outward the chain rubs the chain stay. With the offset inwards it rubs the tire. I guess I'm going back to my 44 tooth. Is there any reason these sprockets are built this way?
  2. azbill
    azbill Active Member
    May 18, 2008
    3,367
    with it dished out, try a washer or 2 on the axle, it might give you the clearance you need
    hope that helped :)
  3. fm2200
    fm2200 New Member
    Nov 16, 2008
    258
    I just spread the rear stays and that gave me the clearance ( about 1 1/4 inch ) and put washers on the rear axle to give the proper spacing.
  4. DAVID02895
    DAVID02895 New Member
    Nov 14, 2008
    23
    Will the sprocket adapter work on the occ schwinn stingray? When will you have them?
  5. Creative Engineering
    Sep 20, 2008
    1,668
    Yes they do...I machine all of this stuff in my shop. They will be ready next week. I have the OCC here, so you don't need to measure your wheel.
    Jim
  6. DAVID02895
    Nov 14, 2008
    23
  7. Creative Engineering
    Sep 20, 2008
    1,668
    David,
    That hub appears to be eliptical in shape, my sprocket adapter will not work on that type of hub.
    Jim
  8. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    16
  9. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    my three speed street series chopper has that same hub. any ideas on how to mount a sproket on it?
  10. commander
    commander New Member
    Mar 19, 2009
    205
    Hey Jim, when do you think the adapters will be ready? and what is the price ?
  11. DEATH4OF4
    DEATH4OF4 New Member
    Mar 22, 2009
    108
    Has Anyone Used A Laser Level To Get The Alignment Perfect?
    I've Been Using A #41 Chain I Got From Fleetfarm .its Wider And Allows For Some Wobble. I Have Messed With That Rear Sprocket Forever Just To Get It Straight But It Never Works . I Bought A Clam Adapter And It Helps Alot. It Still Has Movement.
