Wanting to do something different
Discussion in 'Motorized Bicycle General Discussion' started by dodge dude94, Jun 17, 2013.
  1. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    You guys are not good for my health, I swear.
    Been reading about this build, and that build and whatnot. And it's made me want to do something different with my bike/engine. Currently the engine is running great, sans the carb. So what I need to figure out is what I should do differently here. I can't decide if I want to sell the bike outright, and try to recoup some cash for another build. Or yank all my components off this frame, sell the frame, if that's even possible, and buy a new frame to put all my already-broken-in parts on. I think that would be easier than option 1 as I don't have to re-invent the wheel so to speak, with a new kit. I've already gotten this one broken in and running well, so it would be a matter of adapting it to a new frame.
    The third option is to freshen up my current bike and try to make it a bit sportier, which, honestly I don't think I can do with my lake of resources. I was thinking about just flipping the handlebars over and going with a BTR-lite sort of look.
    Any input would be nice, I'm going mad I swear. lol :):-||
  2. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    Pictures of your bike would help.
  3. dodge dude94
    Jun 8, 2012
    1,017
    Disregard the lack of air cleaner in these pictures, it was off for testing.
    [​IMG]
    [​IMG]
  4. dodge dude94
    Jun 8, 2012
    1,017
    *bump*
    Come on, guys, needs some opinions here..
  5. WightBoy
    WightBoy New Member
    Aug 30, 2012
    271
    I say flip bars or go with 11"ish ape hangers. Get yourself some front springer forks whether it be monark or the bent springer style. If you do bent springer, go ape hanger though. Also, get a different set of breaks. I am running drum front and coaster rear and it works and looks great. Maybe get some wire loom and route your cables for a cleaner look. Just my thoughts.
  6. dodge dude94
    Jun 8, 2012
    1,017
    I'm likely going to flip the bars until I decide on what mtn bike I'm going to get. I think I've decided I'm going to freshen this bike up then later on rip it all out and put it on another bike.
    I'd like to get better brakes for this one, but drums are rather expensive. lol When I get around to it I'll replace the pads for some Kool Stops.
  7. maniac57
    Oct 8, 2011
    4,486
    Best thing I can suggest for a poor builder like myself is to collect every single bike you can find for parts. Cheap bikes are everywhere and I get some of my best ideas staring at junk.
    You need maybe $150-$175 to buy a small welder and a grinder which allows your inner Frankenstien to run amok.
    Come over to The Dark Side....Muahahahahahaha!
  8. dodge dude94
    Jun 8, 2012
    1,017
    Now we're starting to run into the space and money thing. lol I looked at other bikes today to see what options there were. I'm thinking I want to make an off roader. I might just do a little something until i can scrape up the cash for a new bike. lol
  9. xseler
    xseler Well-Known Member
    Apr 14, 2013
    2,833
    74
    Has anyone tried running a 26" front and a 24" rear wheel? Kinda make it look like a dirt bike.......the 24" wheel should give a little bit more low end ummph for an off-road setup.
    Just typing out loud..........
  10. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Yep, I run the 24" rear wheel on my oldest build and run a 32T sprocket on it, works great, the engine is the weakest one I have with no mods to it accept a home built exhaust and a well tuned carb and it will cruise nice at 30+mph and top out at 39mph.
    in the pic if you look real close you can see the Aluminium angle I used to make brake extensions so that the brakes for the 26" wheel can still be used on the 24" wheel without having to relocate the brakes mounting spot, its a bit crude and I plan to make changes to it in the future but it was a quick fix/rig to get it on the road with a rear brake, if you use a coaster brake wheel and dont use a hand brake of coarse this will not be of interest to you, but just thought I would add what I did in that case so that question would be answered in advance if thought of by someone.
    as you can see my bikes stay on a dirt road a lot since I live several miles from the nearest town, always dirty and used well.... just part of country living...LOL!
    Hope this answers you question.
    Peace, Map
  11. mapbike
    Mar 14, 2010
    5,380
    [​IMG]
    Hopefully a bigger and better pick of the dirty old bike.
  12. dodge dude94
    Jun 8, 2012
    1,017
    Interesting. I've thought about running a 24 in wheel before. I've got an old 18 speed 24" mtn bike from when I first started riding. Thought about swapping the fork onto my cruiser, but decided it wouldn't work due to the larger wheel size of the cruiser.
    UNLESS IT WOULD??!!?!?!?!?!?
    :D
  13. mapbike
    Mar 14, 2010
    5,380
    I always run 1.95 size tires on mine. The Kenda cross type tires have given me great service and they arent to wide to work on most bike cruiser or MTB.
  14. dodge dude94
    Jun 8, 2012
    1,017
    I'm running 1.75s right now. They have enough room to play with. My 1.95 mtn tires I had on it at one point BARELY squeeked by.
  15. mapbike
    Mar 14, 2010
    5,380
    My 1.95's do brush against the chain just slightly from time to time but never in anyway do the tires or the chain take on any damage , a couple of washer behind sproket on each bolt spaces the chain out approximately 1/8" to 3/16" which will give even more room if needed. Only tires I've never run on mine are the 2.25 cruiser tires but I know I can make them work with the right amount of shimming of my driven rear sprocket. I will work on that in the future , I know I would enjoy the smoother ride I would get on these rough dirt roads I have to ride for 3 miles before I get onto the highway that leads to town.
  16. Desert Rat
    Desert Rat New Member
    Jul 30, 2012
    565
    Looks nice as is, make a side car! or a nice pop up trailer for it
    My fave would be a side car with a fake pvc 50 cal machine gun That'll
    get you some looks hahahaha:)
  17. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
    If you want a different wheel look, then go more practical- a 700c or 27 skinny wheel on the front- like a real "chopper"-
    you'll feel the difference peddling right away, and the motor feels it too- a speed increase guaranteed!
    recommend- a 3/4" (19mm) rim and a tire no wider than 32mm-
    and then you can go (have to go) with a shorter reach LIGHTER alloy brake-
    all kinds of weight savings AND a better roll. win-win.
    Are those current rims steel? Definitely heavy then-
    And it looks like you need a lot smaller rear sprocket for some crusin speed, sans WOT. 36 are great for normal street use, unless very hilly or very heavy.
    #17 Nashville Kat, Jun 21, 2013
  18. dodge dude94
    Jun 8, 2012
    1,017
    My bike used to have 2.125 cruiser tires on it. It was squirmy and handled poorly. The 1.75 hybrid tires makes it more planted even though it ride rougher.
    Considering I've got lots of PVC sitting around, don't tempt me. lol
    Here's the thing, I'm likely going to be going a totally different route in the near future, so I can't spend a lot of money on this frame. The current rims ARE steel, yes, but if they were single wall aluminum like some guys have on here, they would have been taco'd long ago. And how can I go with a short reach brake without welding a new set of brackets onto the frame? lol The thing about the 44t sprocket is that it pulls like a train up hills. I can do 22 easy up a 25% grade. :D
    #18 dodge dude94, Jun 21, 2013
  19. LR Jerry
    Dec 19, 2011
    1,027
    As far as a money thing goes my X-wife always said I loved my bikes more than her. LOL
  20. dodge dude94
    Jun 8, 2012
    1,017
    Well, I'm just broke at the moment and my truck takes presidence over the bike. lol Bike is a play thing, truck is transportation. lol
