Want to try 10hp trike..
Discussion in 'Motorized Bicycle General Discussion' started by Peach, May 4, 2013.
  1. Peach
    Peach New Member
    May 4, 2013
    Bored with my HS49, no gears just two sprockets. It works as a top speed adder at best. Does stay fast but takes a while to build up speed.
    I was thinking of getting a big horizontal Honda engine and mount it on the back of the trike and go from there.
    I dont think i would attract much police attention as long as the trike was narrow and stayed under the speed of traffic. I dont want to be passing everyone lol
  2. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    10hp is a LOT of power, especially for a trike.
    Maybe all you need is a bigger rear sprocket for more low end power. Which sprockets do you have now?
  3. Peach
    Peach New Member
    May 4, 2013
    44t rear and like 10t front. Speaking of sprockets, it doesnt spin straight, a new one might be in order
  4. 5-7HEAVEN
    Aug 2, 2008
    2,364
    #4 5-7HEAVEN, May 6, 2013
  5. Peach
    Peach New Member
    May 4, 2013
  6. 5-7HEAVEN
    Aug 2, 2008
    2,364
    Here's one:
    http://www.mmbikeparts.com/sprocket_adapter.htm
    If you look to the top right sponsor's list, you'll see another one.
  7. Peach
    Peach New Member
    May 4, 2013
    I just realized, running a larger rear sprocket will reduce my top speed. I should go for a larger drive sprocket and smaller rear sprocket for my purposes. I want to maintain higher top speeds in the straightaways. I could live with suffered climbing performance in hilly areas. This is where having a two gear setup for acceleration when i need it and top speed
  8. 5-7HEAVEN
    Aug 2, 2008
    2,364
    Any pictures? Multi-speed setup works well for guys wanting both low end and top speed.
  9. Peach
    Peach New Member
    May 4, 2013
    Its just a basic hs49 setup
    [​IMG]
    [​IMG]
  10. racie35
    racie35 Active Member
    Nov 17, 2012
    1,700
    [​IMG]
    I put a tanaka on this but we are now changing it over to honda 160....you dont want to go too fast on a trike..theyre scary
