vibration under part throttle
Discussion in 'Motorized Bicycle General Discussion' started by SledKicker, Jul 10, 2013.
  1. SledKicker
    SledKicker New Member
    Jul 10, 2013
    6
    i've noticed my 66/80 beach cruiser runs way smoother at full throttle or very light throttle. at about half throttle or while cruising above 20mph it vibrates like crazy. what could be causing this or is it normal? goes away as soon as i give it the beans again.
  2. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Is the engine mounted solid to the frame? Loose or ill fitting engine mounts can contribute to vibrations.
    Some vibrations are normal. Single cylinder 2 stroke engines vibrate. Its just the nature of the beast. Depending on how they are mounted determines how much of that vibration is transfered or absorbed by the frame.
  3. SledKicker
    Jul 10, 2013
    6
    i will recheck my mounts, thank you.
    i just went on a long test ride. lots of power, but under part throttle it 4 cycles. runs great WFO
  4. maniac57
    Oct 8, 2011
    4,486
    That's what you want for best overall engine life. Tuning for max power is risky and expensive if you mess up and go too far...
    Love her for what she is and don't expect her to break speed records and you will be happier in the end.
    Just sayin
  5. SledKicker
    Jul 10, 2013
    6
    Where did you get that i want a speed demon? I am complaining about a cruising condition :)
    Not that blowing a motor is a huge deal when parts are this cheap. Ive all but stopped playing with full motorcycles since finding this hobby!
  6. maniac57
    Oct 8, 2011
    4,486
    Not hacking on you, just meant a bit of four-stroking at steady throttle is about right as far as jetting.
    Pulls clean under acceleration then it's good.
    Go leaner till you like it if you are not worried about wear and engine life.
  7. fatdaddy
    fatdaddy New Member
    May 4, 2011
    1,516
    Mine 4 strokes some too. But at WOT it SINGS to me. I'm not gonna worry about it though, it runs good enough and is hitting around 35mph. 2door is probably right about the mounts. A loose mount will make yer hands all tingly with all the vibration.
    fatdaddy
  8. SledKicker
    Jul 10, 2013
    6
    Oh i didnt know 4 stroking at part throttle was ok. Thanks guys!
  9. fatdaddy
    fatdaddy New Member
    May 4, 2011
    1,516
    You could probably work it out with A LOT of experimenting with the porting, carb tuning, fuel mix, ect, ect. It's probably running just a little rich, which is better than running too lean. If it has a good pull all the way to the top end I'd leave it alone and just enjoy the ride. Just my humble opinion.
    I would be more worried about the vibration. I would replace the chinese mount studs and nuts with a better grade and make sure they are TIGHT.
    fatdaddy.
    #9 fatdaddy, Jul 11, 2013
  10. SledKicker
    Jul 10, 2013
    6
    Thats exactly what i will do then. Thank you
