vehicle nitrous regulator
Discussion in 'Motorized Bicycle General Discussion' started by kzbesner, Jun 10, 2011.
  1. kzbesner
    kzbesner New Member
    Jul 26, 2010
    34
    i just recently baught a large nitrous tank meant for cars, but am wanting to put in on my bike.
    is there anything out there that can regulate the amound of nitrous flow into the engine soo that im not waisting any as well as blowing up the engine with a nitrous overload?
  2. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    If you plan on using Nitros on one of these china girls you may want to buy a few extras because you'll likely melt them left and right.......
    The wrist pin bearings in these engines dont even handle very high compression for very long, so the Nitros will likely cook it pretty quick unless you are only using a very very small shot for a verty very short period of time and injecting an extra bit of fuel oil mix as well to keep from creating a major lean condition that will kill these 2 Smokers pretty quick.
    I could be completely wrong, but I just dont see these engines holding up to very many shots of Nitros....
    Just my $.02 because I dont want to see you melt an engine..... but if you do it and it does work please be sure to post info. and video of the results.
    Peace
  3. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    The nitrous tank is worth more than the motor.
    Yeah baby!
    Melt the sucker - laff
  4. sketchman
    sketchman New Member
    Mar 23, 2011
    168
    Install a needle lifter, to fatten it when you tickle it?
  5. kzbesner
    kzbesner New Member
    Jul 26, 2010
    34
    what i was thinking is getting a mettal/plastic water bottle.
    on the bottom, bore a hole for the nos intake, feed a high comp. hose into the bottle and seal it( wether it be jb weld, or epoxy, w/e)
    then bore a hole in the lid, and place a small thin-tubed valve into the hole and seal t wichever what way, then have a hose attatched to this valve and have it simply lead into the air intake.
    what i was thinking is pressurize the bottle with NOS and once pressurized, turn off the nos tank valve and open up the small halve at the lid.
  6. kzbesner
    kzbesner New Member
    Jul 26, 2010
    34
    and this is a crap engine that is at the end of its life... i dont care to melt it other than for my safety...
    trust me, there will be vids
  7. kzbesner
    kzbesner New Member
    Jul 26, 2010
    34
    btw, the tank weighs bout 45lbs...guy that sold me said its 80lbs wich im assuming there is 80psi of nos inside this sukker.
  8. Bruce Lee
    Bruce Lee New Member
    Dec 13, 2010
    46
    Nitrous oxide tanks run about 900 to 100 lbs at full. On a china 2 stroke without extra gas added stay at about .004 on the spray nozzel. And then for only about a 2 second shot every 5 seconds.
  9. tim turbo
    tim turbo Member
    Nov 18, 2009
    186
    What a WASTE!!!!!!!!!!!!!!!!!!!!!!!!!!
  10. decoherence
    decoherence New Member
    Aug 23, 2010
    476
    if carried out i could see this being nominated for the darwin awards.
  11. kzbesner
    kzbesner New Member
    Jul 26, 2010
    34
    hahahaha, w/e u all say XD bein famous aint a bad idea
