v belt drive gearing
Discussion in 'Motorized Bicycle General Discussion' started by ragdolldude, Jun 1, 2016.
  1. ragdolldude
    ragdolldude Member
    May 6, 2016
    Just introduced myself the other day. I noted I was getting a v-plex clutch that is NOS. Idle, and the clutch doesn't operate. Increase rpm and two tapered sides of pulley pull together increasing diameter of pulley. Goes from around 1 1/8" up to about 2 1/4" diameter pulley. I don't want to use a jackshaft, and was wondering what size sheave to use on rear 26" tire. I plan on using a Honda Gx50 engine, likely on a cruiser frame, mid frame mount. I initially thought the 15 inch whizzer sheave would work, but others have suggested a 24 inch narrow bike rim as a sheave, bolted with brackets to rear wheel. I assume someone has already done this and was hoping to benefit from your experience, instead of tying different sheaves. Thanks
  2. MEASURE TWICE
    MEASURE TWICE Active Member
    Jul 13, 2010
    2,125
    23
    http://motorbicycling.com/showthread.php?t=28803&page=65
    This thread of Harry76 has been around from the past. A lot of pages here too. There are many pictures that used some way of posting that don't show up anymore, but this page has a close up of what he made with a ? 24inch rim as a sheave.
  3. Tony01
    Tony01 Active Member
    Nov 28, 2012
    974
    29
    Use a 26" skinny rim for your sheave, but you'll have to widen the frame in the back... By cutting and welding. This will give a 13:1 ratio in top gear.
  4. curtisfox
    curtisfox Well-Known Member
    Dec 29, 2008
    4,127
    52
    Yes that might be better yet, and easier to mount straight tabs. And with the high rev Honda would give you a good top speed.................Curt
