ughhhhh
Discussion in 'Motorized Bicycle General Discussion' started by ct66rider, Mar 2, 2010.
  1. ct66rider
    ct66rider New Member
    Jan 20, 2010
    33
    so i broke my rear motor mount stud inside my motor and its drilled out but i have no easy outs small enough for it. is there any other ways to get out a busted bolt?
  2. taddthewadd
    taddthewadd New Member
    Mar 1, 2009
    339
    I bought an easy out small enough for that at OSH for 4 bucks. An alternative that might work is to cut a slot in it with a dremel cut off bit and use a small flat head screw driver. The only problem with that is when you cut the slot you will end up cutting some of the engine case also depending on how tight the stud is in there you might not be able to get enough torque on the stud to get it out that way.
  3. jimrandolph
    jimrandolph New Member
    Nov 28, 2009
    44
    I have used a jewelers file and cut 2 slots inside the hole, then get the same size screwdriver and back it out. It worked for me.
    Jim
    .trk
  4. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    I've lightly tapped the tang of a file into the hole and backed them out
  5. aspireonescs
    aspireonescs New Member
    Jan 4, 2010
    64
    the dremel trick worked for me, but what i did to minimize the case cutting was to use a cutoff disc that was worn down in diameter so it wouldent cut the much of the case, good luck :)
  6. bairdco
    Aug 18, 2009
    6,377
    37
    left threaded drill bits work. (sometimes)
    last resort, really big hammer.
  7. stv1jzgte
    stv1jzgte New Member
    Feb 11, 2009
    489
    The only way its gunna come out is if you weld a nut to it, beg borrow or steel but thats it.
