Two cycle oil
Discussion in 'Motorized Bicycle General Discussion' started by gphil, Aug 20, 2011.
  1. gphil
    gphil Member
    Jan 9, 2011
    274
    After reading tons of posts about this subject guess I will have to go with Valvoline 2 stroke oil. I have checked all the shops in this small town and they just do not carry the Opti 2. I was leaning towards that brand,,,, oh well. I actually read a post that said the opti 2 caused a engine failure but who knows conditions. So after this rant what you think of the Vavoline. New engine and going to stick with it. Oh yeah read where some of these mixtures do not like the new fuel mixtures either. Ethanol I think. A boat marina close by sells regular gas , so there ya go. Small touches on the bike going on now so expect a launch maybe next week. gphil
  2. socialdistortionkid
    socialdistortionkid New Member
    May 14, 2011
    187
    Yamalube 2R in all my 2 Strokes, i have little to no carbon buildup which makes my top ends last a long time. No problems with it, I can run 50:1 if i wanted too.
    Next oil i would choose is Klotz or Castrol. I dont like Castor 927 because its a bean oil and it makes alot of carbon buildup
  3. WildAlaskan
    WildAlaskan New Member
    Sep 30, 2010
    581
    i just use pennzoil multi-purpose 2 stroke oil before that all i had was evinrude outboard oil my bike runs just fine i usually run er around 24 to 1
  4. dmb
    dmb Active Member
    Dec 4, 2010
    1,359
    what were these engines made to use in russia and china? answer; crap gas and crap oil outa crap storage drums [water,rust.crap.body parts?] i think just about anything in the usa should work o.k. some better than others.I remember japaneeze fish oil forks and shocks from the 60's.
  5. Pilotgeek
    Pilotgeek New Member
    Apr 6, 2011
    403
    Klotz is pretty good. I run Amsoil.
  6. decoherence
    decoherence New Member
    Aug 23, 2010
    476
    there has only been a couple of people that claimed to have issue with opti-2. also most of the arguments with opti-2 is what ratio. i was using 72:1. i just put in a tank of 100:1
    but i'm not here to convert you.
    go to your local lawnmower sales shop. (not a box store like walmart/kmart)
    they will have tons of oil & tell you why the one they use is best.
    go with it.
  7. gphil
    gphil Member
    Jan 9, 2011
    274
    Thanks guys just want the thing to perform right just like to hear from the pros now and then. I do not believe the local small engine shops here carry the Opti 2. I like the way it sounds on their web so I will do what I have to do. Very helpful and thanks. gphil
  8. lowracer
    lowracer New Member
    Oct 17, 2008
    1,319
    I'm running Yamalube 2R in both my pocket bike stage 2 engines @ 32:1 & they run out strong @ very high rpm's.
    -Lowracer-
  9. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    If you really want to try Opti2 just go to your local Tractor Supply if you have one in your area and pick up a pack of Arnold The “1” Universal Mix for all 2-cycle engines, this is Opti2 packaged for Arnold, same stuff all the way.
    http://arnoldproducts.com/_pdfs/_oil_lub_fluids_and_parts/Oil-Arnold-1.pdf
    But like it has already been said here, any of the good 2 smoker oils will do just fine in these engins, just mix it right and tune the engine for the mix and get the air/fule mixture right and you will have a good running engine that should hold up as good and long as the wrist pin bearing and seals will let it go.
    Peace, map
