Twist grip clutch??
Discussion in 'Motorized Bicycle General Discussion' started by greasy tom, Aug 4, 2010.
  1. greasy tom
    greasy tom New Member
    Feb 9, 2010
    15
    I have had several clutch lever problems on my cruiser w/ 80cc Chinese kit, although mostly minor I'd like to come up with something more durable.
    I was looking at a throttle twist grip assembly and wondered if any of you folks ever tried to replace the clutch lever with a twist grip?
    I was wondering if the leverage and cable travel would be adequate or do you think this is just a "carpal tunnel" candidate?
    I found a source (see link) for these throttle grips for $ .99 each which got me to thinkin'..........
    https://www.surpluscenter.com/item.asp?item=1-1935&catname=
  2. professor
    professor New Member
    Oct 14, 2009
    501
    The difference between your gripping ability and your holding an turning ability is substantial. If your clutch was real light in pull- you have a shot at it.
    The HT clutch I grabbed was like a bear trap.
    Look at making the angles better down on the engine.
  3. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    Here is a solution..reduces clutch handle pull by at least 80%...for more information shoot me a PM.
    [​IMG]
    #3 Al.Fisherman, Aug 5, 2010
  4. noco
    noco New Member
    Sep 9, 2009
    344
    is your clutch cable hooked up correctly??? the large spring is a heat sheild and shouldnt be in between the mount and arm....just an idea cause a friend of mine had clutch lever problems and it was due to him miss placing that spring....he was getting a strong left forearm pulling that through all the stop signs in town
  5. Bikesnfire
    Bikesnfire New Member
    Jul 17, 2010
    50
    I use the 3 speed Sram grip shifter for the clutch. It locks in different positions and is very easy to operate. I have 4 bikes using them right now and I really like the way they work. The clutch levers supplied with the kits are basically junk. I say give a grip shift a try. Mine work great and my future builds will have them also.
  6. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    Cable lube isa wonderful thing ;)
    I'm really not being snarky lol - I keep seein' ppl complain about the stiff clutch and the junk levers, even folks around here where I live... yet I've found if the smaller spring that's "supposed" to help with return is discarded (not the bigger heat shield one) as unnecessary, the cable itself is routed smoothly w/o sharp bends and well lubricated (it's dry out of the box), even a lil dab o'grease on the actuator pivot & ramp - and the clutch becomes remarkably light & easy to pull...
    I suppose there could easily be variance from kit to kit, but I've "tuned" five bikes like that so far with excellent results *shrug*
    Not to say that a twist clutch wouldn't be neat (one less lever) or that the pulley mod isn't interesting - but I've simply not found them to be necessary for the reasons stated...
  7. Al.Fisherman
    Sep 9, 2009
    1,966
    While I agree with you, I also discarded the spring, lubricated the cable and made as smooth a route for the cable/housing, my clutch wasn't all that bad. I picked up the roller idea from a member on another forum and thought I try it to see how well it worked. I have both, more materials and tools then the above average bike builder, so making one wasn't a issue. With the roller I can tie a piece of 6# test mono fishing line to the handle, pull and disengage the clutch (that makes it a one finger operation if you choose). I doubt, that can be done with the best installed OEM clutch cable set up using the original mounting. I get nothing but praises when the roller mod is used.
  8. BarelyAWake
    Jul 21, 2009
    7,209
  9. LouieMCman
    LouieMCman New Member
    May 28, 2010
    137
    Twist grip clutches were used on some motorcycles back in the early days (1900-20). Of course the clutches were more primitive but they seemed to work as well as moving a lever along side the tank, this was before they had foot clutches. So I don't see why it wouldn't work in today's world as long as your clutch is working properly.
