Trike Project or not
Discussion in 'Motorized Tandems, Trikes and Recumbent Bicycles' started by Jim C, Dec 21, 2015.
  1. Jim C
    Jim C New Member
    Jul 11, 2010
    190
    I have a 49 cc HS 142F motor with a 4g drive. I bought this to use in a 2 wheel bike and changed my mind and used a 66cc 2 stroke instead. I am thinking of using the HS in a trike. Most of them are a little "tippy" in corners. I am thinking that smaller and fatter rear tires with the motor mounted low in the back ahead of the wheels might add some stability.
    I would do away with the basket, lower everything and use a balloon tire on the front with maybe 20 or 24 fats on the back, some pull back bars and a big fat seat. I think I could make a good looking comfort cruiser trike.
    Any thoughts?
  2. 2door
    2door Moderator
    Staff Member
    16,287
    Sounds like a good plan, Jim. You posted this in the right section. You might want to browse through the older threads here to see what other members have done with their three wheelers.
    I've only built one trike but it was an unusual design. I used a Titan 49cc 4 stroke in it and because of the tiny front wheel it was a little unstable at speed. A more traditional tricycle design would be a better option for a neighborhood cruiser.
    Keep us posted if you do this project.
  3. curtisfox
    curtisfox Active Member
    Dec 29, 2008
    3,762
    That sounds like a good plan, like Tom says bigger wheels.............Curt
  4. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
    Trikes can be tippy for sure. Your approach brings to mind a Bigwheel toy trike....small rear and huge front. Thing is you'll struggle to attain that stance and all.
    On my own trike I stretched it a bit and widened it as much as my eyes could take. Then we pushed it down hill fast and tried it ,full lock turning it in a hurry. It remained stable and when it hit sand just slid around. So the ratio...length to width and height, must be close.
  5. Moto22
    Moto22 New Member
    Mar 19, 2017
    8
    did you pursue on this one?
