Tooth sprocket question...
Discussion in 'Motorized Bicycle General Discussion' started by ueyteuor, Jul 23, 2010.
  1. ueyteuor
    ueyteuor New Member
    May 28, 2010
    37
    Hi there, I need some advice... I just purchased a grubee 66/80cc starfire kit... though i do not know how many teeth the sprocket it includes has...
    Anyhow, what I am wondering is what type of sprocket tooth count would be right for my bicycle? Bicycle wheel is 20"!! So this is why I am wondering, since I don't see many motorized bicycle with only 20" wheels...
    Another concern is that where I live there are many hills... which sprocket would be best for pedal-helped hills, and with the fastest speed, on 20" wheels...
    Thank you!
  2. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Probebly a 40 to 44 tooth came with it,,,,that on a 20 inch wheel would possibly be able to climb trees,I don't know if they make a gear ,for 20 inch wheels,that would need pedaling help on hills,I'm thinking the smallest is 36 teeth.someone may know of others
  3. bairdco
    Aug 18, 2009
    6,403
    50
    the smaller the wheel, the quicker the acceleration. you can get away with a smaller gear than the average 26" bike has. in theory, you'll need a smaller sprocket to get up to top speed, compared to a bigger wheel.
    like, if a 26" had a 46 tooth, you'd need a 36 to keep up (i'm just guessing, i'm sure there's an equation somewhere that'll tell you actual wheel diameter + sprocket size = speed..)
    there's people that claim a smaller bike won't be able to keep up with a larger wheeled bike at top speed, but in the real world, they're wrong.
    with a 20", you could run a 30, or even a 28 and still climb hills, as long as your engine is tuned right.
    i have a 24" with a 30 tooth, and i've run 30mph+ up 6% grades.
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    A 20" bike? I thought that's what those 27T sprockets were made for?
  5. xzackx
    xzackx New Member
    Jun 30, 2010
    44
    i have a question my scwhinn has a 24'' front and a 20'' back tire i have a stock gear on mine should i upgrade to a lower tooth gear?
  6. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    62.83 inches per turn on a 20 inch wheel/
    81.68 inches per turn on a 26 inch wheel/
    about 25% less travel
    40 tooth divided by 4 =10, x 3 =30 tooth ?
  7. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    75.4 inches travel on a 24 inch tire
    12.96% shorter than 26 inch wh.travel
    about 1/8 difference
    40 tooth divide by 8 = 5,x 7 =35 tooth ?
  8. ueyteuor
    ueyteuor New Member
    May 28, 2010
    37
    Very nice equation!
    Thank you all for your help... i'll be looking for either a 27T or 30T sprocket...
  9. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    27 would be for more speed on the flat lands ,and less power on the hills,your weight will play a part,100-145 pounds 27 tooth,above that I would do the 30 tooth(or more w/cargo being carried),,,,,simi trucks dont hold 65 mph on hills and gear down (same as putting a larger gear on their rear axle) to climb the hills and use the power their engine has w/out boging down, slower speed "but works",,,,,,,,,,,,,
  10. ueyteuor
    ueyteuor New Member
    May 28, 2010
    37
    Thanks! So I guess I should settle for 27t, I am a light person...
    Do you know where I can get a 27t that's a direct fit? If not I would probably just have to find a 27t and have the mounting holes made custom...
