tools needed
Discussion in 'Motorized Bicycle General Discussion' started by Juhstun, May 18, 2012.
  1. Juhstun
    Juhstun New Member
    May 17, 2012
    21
    could someone give me a list of ALL the tools needed to install a 2 stroke motor onto a beach cruiser, and also the tools to maintain the 2 stroke bicycle
    so im looking for a list of all tools for installing and maintaining 2 stroke engines. thanks!
    i have 100 in my pocket so im hoping to get the majority of the tools with 100 maybe?
  2. 2stroker
    2stroker New Member
    Apr 29, 2012
    168
    What 2stroke engine are you going to buy? Some of the manufactors of the kits have installation video's that tell you everything you will need to install the kit. I have a set screw drivers, allen wrenches, T-drivers(star bits),Ajustabble wrench, a set of sockets and that takes care of all my motor installation and maintance needs. I have a sleak container a tube 4x4 in diameter and about 14 in long. I carry all i need to work on my bike with me at all times!
  3. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    These are pretty much the bare minimum.
    Screwdriver Philips/slot Harbor Freight $4.99 (12 piece set)
    Combination wrenches, (2)10mm, 13mm:confused:, 14mm (buy the hole set both Metric and SAE $19.99 HF)
    3/8" metric/SAE socket set HF $9.99 - (51) pieces
    Whatever needed for the bicycle
    I recommend a inexpensive inch torque wrench (Ebay)
    http://www.ebay.com/sch/i.html?_nkw...h&_sacat=0&_odkw=inch+torque+wrench&_osacat=0
    Gear puller if not supplied with the kit. ($6.50) Order with kit, maybe no extra shipping.
    http://www.ebay.com/itm/bicycle-Mot...503?pt=LH_DefaultDomain_0&hash=item256bc24bff
    13/16 spark plug socket w/ ratchet Usually included in a socket set.
    Drill and 5mm bit to drill hole in handlebar for throttle. Cheap cordless HF $10.99
    Multimeter, Harbor Freight $5.00
    Sheet of 230 or finer sandpaper $0.10-$0.50
    File
    Chain breaker
    Solder and gun/iron or pencil
    https://docs.google.com/document/d/1GcesQihc7-mm3hJGf7UPiqOaRXZ8ekUT99QUZq2qXXE/edit
    #3 Al.Fisherman, May 18, 2012
  4. Juhstun
    Juhstun New Member
    May 17, 2012
    21
    im not sure which 2 stroke engine i will buy yet.
    i currently just have a mb with carb issues already and want to get all the tools neccesary to fix all the problems mb's come with.
    the tools for installing the engine is for later down the road when i make another bike which i will
  5. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,927
    89
    Heat shrink or wire loom and cable ties to clean up the look helps also.
  6. killercanuck
    killercanuck New Member
    Dec 17, 2009
    1,749
    Basically, you'll need a 10mm, an 8mm, a philips driver and some needle-nose pliers(for the chain master link). That's it. That'll get it on there and running. A 10mm will be your best friend from now on. The 8mm is for the gas tank and cdi mounts, but you can do those with the needle-nose, so you don't even really need the 8mm.
    You might want a second 10mm for getting the drive sprocket on...
    gl.
    #6 killercanuck, May 19, 2012
  7. Juhstun
    Juhstun New Member
    May 17, 2012
    21
  8. killercanuck
    Dec 17, 2009
    1,749
    I never said 13,14 etc
    2x10mm's, Philips, and needle-nose, that's all I said. In the long run, you'll want more and better tools for proper bicycle maintenance, because you don't want to be riding around on a death trap, right?
  9. Al.Fisherman
    Sep 9, 2009
    1,966
    #9 Al.Fisherman, May 19, 2012
  10. Bikeguy Joe
    Jan 8, 2008
    11,529
  11. fastfingas
    fastfingas Member
    Dec 25, 2011
    99
    those are some good suggestions go get all that!and don't forget a roll of duct tape now you're set!!!!!!!
  12. Juhstun
    Juhstun New Member
    May 17, 2012
    21
    nvm lol....
  13. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,646
    65
  14. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
  15. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,646
    65
    LOL, I am in no way responsible for any thing, any where, ever or at any time. Sign here
  16. Bikeguy Joe
    Jan 8, 2008
    11,529
    me too idk lol hahaha
  17. Al.Fisherman
    Sep 9, 2009
    1,966
    He may claim to use (1) 10mm wrench and (1) screwdriver (actually most kits require 2), building 100 bikes but I don't believe that for one second. Its a bunch of BS. Then again, if MacGyver can do all those things, I guess he can.
    Does anyone think that 100 in 100 engines that the head is on tight enough? My experience was 1 for 1 that mine wasn't, causing a blown head gasket. Now I correct that problem before installing the engine. Not to mention installing a tank (8mm) and the tensioner (14mm). This guy is full of S##t.
    #17 Al.Fisherman, May 21, 2012
  18. Ibedayank
    Ibedayank New Member
    Oct 29, 2011
    1,171
    ohh come on now Guys everyone knows it takes a full machine shop and every tool Snap-on and Park make to install a 2stroke made in china motor in a bicycle frame.
    Now you have to use a Tig welder from Miller as no other welder will work.
