Tools- HF tubing roller- anyone used one?
Discussion in 'Motorized Bicycle General Discussion' started by chainmaker, Sep 19, 2012.
  1. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
  2. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    it seams like a good roller i cant see any problems with it since it will do up to 2" pipe it should do a bike frame
  3. 2door
    2door Moderator
    Staff Member
    16,301
    26
    #3 2door, Sep 19, 2012
  4. culvercityclassic
    culvercityclassic Well-Known Member
    Sep 27, 2009
    3,071
    48
    I have one and used it 2 times. Its some work to wheel the pipe back and forth but it turned out well. Make sure you have something solid to mount it to. This tool goes hand in hand with an engine stand...use it once or twice...and lend it to a friend till ya need it again...laff
  5. sportscarpat
    sportscarpat Bonneville Bomber the Salt Flat record breaker
    Jun 25, 2009
    1,725
    26
    I have the HF version and really don't recommend it. If you try to roll a tight radius the two ends start to twist away from each other. If you try to put a radius bend in a certain spot in the tube and leave straights on either end, you can end up with distortion between the straights and rolled area. Sometimes I get decent results, sometimes I don't. Tubing bends need to be flat and distortion free and that can be a challenge with the HF tubing roller. I have no experience with the Eastwood product but it's price may be an indication of a high quality tool.
    Pat
  6. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    its one of thouse things i have one at work like the harbor freight one its a great roller as long as you know what you are doing and have the die kit with the different sized rollers to match the pipe you are working or at least close to the size in it it is great but mine has a bottle jack in it instead of that crappy screw/bolt
  7. RicksRides
    RicksRides New Member
    Feb 22, 2012
    864
    ChainMaker I have found the same issues using the HF tubing roller that Pat has mentioned to address thee issue of turn out I used my torchs and some pressure on the finished rolls and all ended well so my opinion on the roller is its a cheap tool, that will do most jobs on its own but tighter rolls will need the use of other tools, Rick
  8. chainmaker
    Jan 19, 2010
    2,597
    Thanks for the advice, what I need it for is to do a curved toptube and a bottom loop. We all know the quality issues with HF as opposed to the pricey stuff, and the end results. What Im looking for is, is it a piece of crap or will I be able to make it work for what I need.
  9. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    it will do what you need it for as long as you dont want to roll a 1.5+ inch tube into a perfect ring
  10. RicksRides
    Feb 22, 2012
    864
    ChainMaker It will do what you are wanting it to do with out issue. Rick
  11. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
