too much oil
Discussion in 'Motorized Bicycle General Discussion' started by 520titan, Apr 13, 2012.
  1. 520titan
    520titan New Member
    Mar 30, 2012
    7
    ok so accidentally doubled the oil ratio for the gas...i tried to run it but now it starts up but wont get goin if that makes sense...the motor will run as long as i pedal but after i stop pedaling it dies out..does this sound like a symptom of having too much oil...either way im switching out the gasoline now! total blonde moment...i just realized i did it too after a lot of troubleshooting..:-||
  2. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    Pull the line off the carburetor and drain, then drain the carburetor bowl, and go from there.
  3. rustycase
    rustycase Gutter Rider
    May 26, 2011
    2,746
    Well, at least you haven't gone on an extended run only to discover you are running straight gasoline in it!
    Chances are you'll be OK.
    rc
