Tire or rim problem?? I need suggestions
Discussion in 'Motorized Bicycle General Discussion' started by recumbentbill, Jun 16, 2011.
  1. recumbentbill
    recumbentbill New Member
    Jul 5, 2009
    87
    I just had my second flat. Not from a nail or some other puncture but from the tire slipping on the rim which results in the valve stem being ripped . I keep the tire [Armadillo and bontranger thorn tube] properly inflated but after awhile i notice the valve stem slowly moving/slanting prompting me to stop and let the air out and pull the tire till the valve stim is sticking out straight then inflating to recommended psi . Never had this problem on a regular bicycle. This problem is even worse now that my bike has a shift kit. Any thoughts---suggestions on how to keep the tire from slipping
    Thanx
    #1 recumbentbill, Jun 16, 2011
  2. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    I had this same problem. Never encountered it until I got a shift kit, as well. My tires were also technically larger than the 2.125 tubes that were in them. The way I solved it was to use a larger tube. My tires are 2.2 and the tubes in them now are 2.35, inflated to 75psi. My rear tire also has a 2nd tire inside. No problems since.
  3. happyvalley
    happyvalley New Member
    Jul 24, 2008
    786
    I had that happen with thorn proof tubes on one bike with 26" wheels. The thicker rubber didn't seem to 'blossom' inside the tire like thinner tubes and hold the tire despite high psi. I didn't want to forgo the protective no flat aspect so I ended up going with just a thin swipe of craft bond around both beads of the tire where it meets the rim and it stopped the slippage.
    #3 happyvalley, Jun 16, 2011
  4. halfevil333
    halfevil333 New Member
    May 18, 2010
    307
    it's the bontranger tubes!!!!!
    AFTER WAISTING A LOT OF MONEY ON THE SAME PROBLEM i FINALLY REALIZED...DUH! same tubes same problem time and again....Schwinn self-sealing tubes, CAN'T BEAT EM!
  5. Jim C
    Jim C Member
    Jul 11, 2010
    191
    Take the tire pressuer up to the max.
  6. Elmo
    Elmo New Member
    Sep 3, 2009
    749
    I had a Bontrager tire and tube on the rear and had the same problem, pulled the stem off. I used a tube from the lbs, don't know the brand, and had 2000 trouble free miles.
