Throttle to ATV Style Thumb?
Discussion in 'Motorized Bicycle General Discussion' started by mikldom, Jan 12, 2010.
  1. mikldom
    mikldom New Member
    Jan 4, 2010
    33
    Well,,
    My twist throttle took a dump and is broke.
    I was thinking instead of ordering a new throttle, what is the consensus on installing an ATV type thumb throttle?
    I am thinking that when I build up the New one, I will have front and back brakes, and a clutch lever. It maybe easier to work a thumb throttle.
    anybody done this? what do you think?
    THANKS
  2. Venice Motor Bikes
    Mar 20, 2008
    6,213
    24
    A few people here have done that; some like it, some don't.
    I grew up riding motorcycles, so I prefer to keep all the controls the same as on a MC...
  3. bandito
    bandito New Member
    May 22, 2009
    783
    Niagra sells a sweet little thumb shifter that works with most premade throttle cables for about $5. After you get used to it you dont even think about it being different at all. I have that on one bike and the twisty on the other and like them both. The thumb lever throttle came with my DE kit and Ive stayed with it after getting used to it.
  4. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    17
    Here is a Thumb throttle I installed on the RockHopper for a buddy, works great.
  5. bairdco
    Aug 18, 2009
    6,396
    49
    i bought a cheap pit bike thumb throttle and never used it. i was gonna put it on one of my bikes but it kinda interferes with the brake levers i use.
  6. kerf
    kerf New Member
    Jun 28, 2010
    304
    I used to have a finger throttle but it cramped my hand, I now use a twist throttle, hand doesn't cramp it just goes numb. The thumb unit may work better than what I was using.
  7. dmb
    dmb Active Member
    Dec 4, 2010
    1,359
    i remember glamis sand dunes when they were smooth and all of it was open. they had dune cycles, 5 hp fiberglass tubs with 3 wheels and then honda came out with the atc 90 and they had thumb throttles and i had my first thumb cramp. and they will sneak up on you just like that. alot of people switched to twist because once you start thumb cramping it aint going away anytime soon. [twist it around and use your fingers] only lots of riding will cure it
  8. ferball
    ferball New Member
    Apr 8, 2010
    599
    I use to have an old skidoo with a thumb throttle, and I liked it. The build I am working on will have a thumb throttle because my twist got wrecked last year when I dumped my bike. The reason ATV and snowmachines have thumbs is that in a panic or loss of control the thumb is less likely to accelerate, where as a twist or even a brake lever type throttle you may be more inclined to grip and accelerate when out of control or "startled".
  9. 2door
    2door Moderator
    Staff Member
    16,308
    30
    This was probably covered in some of the links Dave provided but to anyone planning on installing and using any type of throttle control make sure it has a spring return to idle. I've read where some guys have used click shifters which gave them "cruise control". That is a very bad, unsafe idea. In a panic situation you'll want that engine to slow down 'right now', not after you have to fiddle with some kind of mechanical release or detent.
  10. dmb
    dmb Active Member
    Dec 4, 2010
    1,359
    ferball you are correct i saw a lot of crashes with twist throttles and a click throttle's only good on a lawnmower
  11. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    My friend's thumb throttle broke, so I gave him mine.
    I just didn't wanna spend $$ on another. Since both brake cables hook up to a dual-pull lever, I simply reinstalled the bike's original brake lever. Then I connected the throttle cable to the left-side brake lever.
    It works well!dance1
