Throttle Mounting: Hole or No Hole?
Discussion in 'Motorized Bicycle General Discussion' started by rohmell, Apr 9, 2011.
  1. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    Just wondering about how others mount their throttles onto the handlebars.
    Do you drill the hole into the handlebar for the pin to go into, or do you grind away the pin and mount it relying on the clamping force of the throttle clamp?
  2. msrfan
    msrfan Well-Known Member
    Sep 17, 2010
    1,779
    36
    I always drill the hole. It assures me the throttle won't turn if I didn't get the screws super tight. Most of my kits had a metal pin, but some have plastic. Either way, I like to make use of the pin. Just have to make sure it's where you want it before drilling.
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    I've always drilled. It in no way compromises the strength of the handlebars and assures that the twist grip stays put. Relying on the plastic and clamping action is not the best idea. It will eventually loosen.
    I've heard of people wrapping the bar with tape, sandpaper and even, heaven forbid, using JB Weld to keep the twist grip in place. :(
    Drill the bar.
  4. DaveC
    DaveC Member
    Jul 14, 2010
    970
    I ground most of the post down leaving a little nubbin sticking out. When I tightened the screws it digs into the aluminum and doesn't turn. I did that because I'm one of the one's that didn't get a instruction manual.
  5. rohmell
    Jun 2, 2010
    1,533
    I've noticed a fascination, even up to the point of fetishism of using JB Weld as a cure and solution to many of the problems found with MBs.
  6. freewheeling frank
    freewheeling frank New Member
    Mar 10, 2009
    440
    i have used jb for so many thing i love the stuff,know a guy that fixed a cracked block on an old farmall tractor worked great, i once rebuilt a rusted out float bowl on a minneapolis-moline tractor, no problems.
  7. ajax
    ajax New Member
    Sep 30, 2010
    10
    i didn't have a drill when i mounted mine and removed the metal nub wrapped the bar with tape and it's fine but i have built a few and prefer drilled.
  8. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Drill babie Drill.........!
