Throttle cable
Discussion in 'Motorized Bicycle General Discussion' started by Bob Mac 18704, Aug 25, 2010.
  1. Bob Mac 18704
    Bob Mac 18704 New Member
    Jan 24, 2010
    127
    Does anybody know how I can shorten my throttle cable. It looks terrible sticking way out like that. The cable is a stock 43 inch and I need about 6 inches cut off it. Are the ends swaged on or soldered or crimped. If their's no way to alter it can I buy a 39 inch cable from anybody. ()
  2. Pablo
    Pablo Master Bike Builder & Forum Sponsor
    Dec 28, 2007
    3,652
    Yes you can cut the cable and housing down. You'll need to solder a new end on.
    You can also get a whole new (nice) throttle assembly from Sick Bike Parts - they come 35" or 41" or 47"
  3. Bob Mac 18704
    Jan 24, 2010
    127
    Which end is soldered on. It looks like the end at the throttle control is just lead and it will melt. I haven't looked at the end in the carb. Back when I worked in a motorcycle shop we used to solder a lot of cables for custom bikes. If these are the same it wont be a problem.
  4. silverbear
    silverbear The Boy Who Never Grew Up
    Jul 9, 2009
    8,188
    10
    Yes, it's the end in the carburetor. Cut off what you want gone as cleanly as possible... a dremel with a cutoff wheels is perfect for the job. Clean up that business end of the cable and use silver solder with flux for silver solder. I find it helps to first wrap a strand or two of copper wire around it as the solder then grabs better. Then use the dremel with a grinding wheel or diamond tip to shape it to the same dimensions as the old stop you removed. I realize you may know all this, but someone else is reading your post who did not know how and now they do. There is a nice video that Norm did on shortening a cable.
    SB
