throttle and clutch cables
Discussion in 'Motorized Bicycle General Discussion' started by mycam8u2, Jun 5, 2009.
  1. mycam8u2
    mycam8u2 New Member
    Dec 5, 2008
    62
    where can i buy clutch and throttle cables that r decent, not so cheap quality. how long is the stock clutch cable? mine got thrown away b4 i got to measure it. well any help will b appreciated.
  2. cabbiex5
    cabbiex5 New Member
    Feb 12, 2009
    47
    thatsdax.com or sbp.com or any other place
  3. reg454
    reg454 New Member
    Jan 11, 2009
    269
    for the clutch cable just goto like dick's sporting goods and get a brake cable line theyt are the same if you need it shorter then cut it don (take the cable almost out before cutting). Don't know about the throttle line unless you get a different carb because their is a little ball at the end of it. If you are try'ing to get it tighter then come up of a way to use spacers to get it tight.
  4. matt167
    matt167 New Member
    May 20, 2009
    420
    it's just a dirt bike throttle cable... the TSC baja 70cc dirt runner throttle cable looks like it would work too
