Threaded rod? Bolts?studs?
Discussion in 'Motorized Bicycle General Discussion' started by Hllygrv0017th, Feb 12, 2016.
  1. Hllygrv0017th
    Hllygrv0017th New Member
    Jan 31, 2016
    Has anyone bought threaded rod or bolt for Home Depot or lowes
  2. sbest
    sbest Member
    Nov 3, 2015
    343
    Yup, and it is weak, low grade stuff. The threaded rod is as bad or worse than the chinese bolts and studs.
  3. Agreen
    Agreen Member
    Feb 10, 2013
    787
    There's good quality studs from places like Ace or TrueValue. I think you can get them in 100mm lengths.
  4. Hllygrv0017th
    Jan 31, 2016
    Thanks for the info I'm looking for aome replacements just for back up without ordering online
  5. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Where are you planning on using it? Cylinder studs? Make sure you get the right thread. Some engines have course threads in the case, some use fine thread. They might be 1.25 or 1 threads. Discard the kit acorn nuts and replace with hex nuts of the proper thread.
    If you're thinking intake and exhaust manifolds, why use studs and nuts? Go with Allen head cap screws instead. Only one set of threads to worry about instead of two.
  6. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,566
    58
    I get 8.8 and 10.9 grades of rod from marshall's h/w - got a store in next town, but avail online too.
  7. sbest
    sbest Member
    Nov 3, 2015
    343
    8.8 is standard ISO grade for industry and plenty strong for these engines. 10.9 may be a little brittle for exhaust and motor mounts but fine for head studs. Studs are kinder to aluminum threads than bolts. Twisting a bolt under load into aluminum is very hard on the aluminum threads and will strip them quite quickly. Most hardware store threaded rod and bulk bolts are lower grade, so read the grade. Metric should be 8.8
    Steve
  8. crassius
    Sep 30, 2012
    3,566
    58
    I use the 10.9 on tensioners - when needed, I can squeeze a round chain stay oval shaped without snapping bolt : )
  9. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,819
    11
    Threaded rod is good for motor mounts and manifolds. Do NOT use threaded rod for a wheel axle. It will end badly.
  10. 2door
    2door Moderator
    Staff Member
    16,304
    29
    The argument against using bolts instead of studs has merit, if, you do a lot of assembly and disassenbly. I try like heck to get things right the first time and seldom have to worry about taking things apart multiple times. I've used Allern head cap screws for intake and exhaust manifolds, engine mounts and in other areas and have accrued thousands of miles on my bikes with no damage to case threads or fastener failure.
    Like almost every aspect of motorized bicycle building you have to decide what works for you. Replacing studs with bolts works for me. You'll need to decide if that suggestion is right for you.
  11. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    i agree wholeheartedly.
    when i was runnin studs, i had them snap every 3-4 weeks.
    since running Allen Key Cap Screws, Yes they break... but not often.
    over 5000miles, 8months, 3 bolts broken, all easily removed. .wee.
