this thing
Discussion in 'Motorized Bicycle General Discussion' started by thxcuz, May 20, 2015.
  1. thxcuz
    thxcuz Member
    Jul 26, 2012
    290
  2. xseler
    xseler Well-Known Member
    Apr 14, 2013
    2,833
    74
  3. 2door
    2door Moderator
    Staff Member
    16,308
    32
    Other than it self-centers the sprocket I don't see much advantage over the kit rag joint. For $45, I'd rather spend a little time and center the sprocket myself. I didn't read everything but what hub is it supposed to fit? They aren't all the same size.
    Just my opinion.
  4. thxcuz
    thxcuz Member
    Jul 26, 2012
    290
    nevermind. I found a clamshell on ebay cheaper
  5. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,730
    83
    that just looks like a clamshell that is held together by a hose clamp - I doubt I'd ever try one if it was on the shelf here
  6. thxcuz
    thxcuz Member
    Jul 26, 2012
    290
  7. dtv5403
    dtv5403 New Member
    May 4, 2015
    322
    Thats a good price for the adapter and sprocket together.
  8. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Yup... that's a good price and I've bought a lot from that guy... he also ships pretty fast
  9. kevyleven007
    kevyleven007 Active Member
    Sep 25, 2008
    1,206
    what size is it?
  10. thxcuz
    thxcuz Member
    Jul 26, 2012
    290
    1 1/2 according to the picture
  11. kevyleven007
    Sep 25, 2008
    1,206
  12. 2door
    2door Moderator
    Staff Member
    16,308
    32
    That's just another 'spring tensioner'. The idea sounds good but the fact is you don't want a spring that allows slack when you least need it. The tensioner, if you have to use one should be mounted solid. Adjustable, but not by a spring.
    When pedal starting or during deceleration the spring will give allowing the chain to loosen. You don't want that. These are a bandaid for improper chain tension and a marketing gimmick.
  13. dtv5403
    dtv5403 New Member
    May 4, 2015
    322
    I see no spring in the picture, nor any mention of it being spring loaded anywhere in the description. Looks like it is mounted solid, to the pedal chain guard tab.
    #13 dtv5403, May 20, 2015
  14. 2door
    2door Moderator
    Staff Member
    16,308
    32
    Run your cursor over the second picture, the one with the part in a package. You'll see the spring.
  15. kevyleven007
    Sep 25, 2008
    1,206
    Huh.? I don't see a problem with the spring load tensioner but I never used one before this is the first one I've seen that looked decent. Another one mounts on the clutch cover and another on the chainstay. I don't like those but this looked like a better way to do it to me. So, are you saying it has too much tension or not enough. Has anybody actually tried this one? It mounts behind the rear mounting plate. Yeah, I know, your probably right. They got a lot of new stuff I never saw before now a days. So, when you pedal start the chain gets to much slack in the top? sounds right I guess
    #15 kevyleven007, May 20, 2015
  16. xseler
    Apr 14, 2013
    2,833
    74
    I concur, Doctor! I'm extremely happy with the hub and sprocket that I got from him.
