thinking bout an 8 spd sturmy
Discussion in 'Motorized Bicycle General Discussion' started by thegnu, Oct 26, 2012.
  1. thegnu
    thegnu New Member
    Sep 15, 2011
    982
    Hey all , my whole family has been loving the mb's I built but only with one complaint when we go out to ride the trike is too slow to keep up with me more specificaly its lacking hill climb power , I know the problem is the 3 spd , so i have been researching 8 spd hubs , the one I am leaning twards is the sturmy s80 8 spd does anyone have any practical experience with it ? an I cant seem to get any onfo on how to convert it to fit the trike , since it has the nexus 3 spd an dual chail rings .
    Gary
  2. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,473
    49
    Bump
    I have never tried em so dunno. Reading around here, have heard good things Gary, but no personal experience.
  3. thegnu
    thegnu New Member
    Sep 15, 2011
    982
    GRRRRRR this is a problem . ah well time an thought will figure it out . thanks Dan
    Gary
  4. Mr. Minecraft
    Mr. Minecraft Visionary
    Jan 13, 2012
    349
    I thought internal hub shifters break easily
  5. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    i herd good things about the SRAM i-motion internal hubs not much on the strumy 5 or 8 speeds
  6. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    The biggest problem with the 8-speed Sturmey is that gears 2-8 are all internally overdriven. 1st gear is 1:1 as opposed to 2nd gear for the 3-speed and 3rd gear for the 5-speed. This means that the 8-speed Sturmey wouldn't offer any hillclimbing benefits over the 3-speed you currently have unless you re-gear the cranks.
    The Sturmey 3 and 5-speeds have proven themselves to be up to the task of motorvation. You might consider the 5 as it has 2 gears below 1:1.
  7. 16v4nrbrgr
    16v4nrbrgr New Member
    Mar 17, 2012
    1,718
    The SRF-3 and SRK-3 have 3rd gear as direct drive, and then 2nd and 1st are underdrive. When the indicator chain is relaxed, the clutch engages the planetary pins and the carrier drives the shell. I've had success with 1000watts electric in a 16" diameter wheel, but shock loading it offroad cracked the driver, which spread the freewheel cover, which jammed the clutch, which stuck it in between gears, which broke pawls. It seems everything is hunky dorey until it machine guns all the guts because of a sequence or combination of errors. The thing I don't like most is having to be gentle on throttle and not crack it wide open from a stop, which is horrible for it if you're in 1st. If you ride carefully it could last you years though, the gears looked okay.
    I say go for anything without pawls. The Sturmey/Shimano cogs with three drive nubs like to fatigue shear and fail, so using a hub with a strong cog mounting is important. I went through 3 Sturmy 16t's with an 80t #25 bolted to it, hopefully that will be a thing of the past since I fixed the chainline which was off due to the hub not being adjustable in chain line if you've got a really wide swingarm. The Shimano sprockets look like they're less beefy than the Sturmey ones, but they might have better mettalurgy.
