Things Ive Learned...So far
Discussion in 'Motorized Bicycle General Discussion' started by HeliHaole, Jul 17, 2010.
  1. HeliHaole
    HeliHaole New Member
    Jun 21, 2010
    15
    Hey All,
    So I got my first bike about a month ago and Ive had an awesome time building and riding it. In my first attempt I got some raked out springer forks... very cool looking but sketchy.
    so off came the forks and I went with the original setup of the bike
    I originally used heavy duty rubber dampeners (the same ones used in helicopters) to mount the engine, justifying that my snowmobile engine has rubber dampeners. The bike was great but lots of vibration at WOT, anyways Im out riding around town and I notice my air box cover and foam and everything is missing. Damn I shoulda tightned that before I left, lol. then a bit further on i stop cuz the engine is moving more than normal. hmm, my rear right side stud has sheared off. oh well better head er home. Soo as im heading home the engine starts missing, cuz its too lean(see above) Now im just nursing it and bamm the rear wheel locks up and the first thing that goes through my mind is, Ive ceased the engine. Nope engine is fine but my chain tensioner is in my spokes. Yep, ive read about it, but wait, the chain tensioner didnt rotate, it bent into the spokes the mounts are still in the same place.That musta been some big chain slap. Luckily I was only a few hundred meters from home. Once I got home I couldn't believe it, the wheel was fine not even a mark on the spokes, But the casing around the engine sprocket is missing a chunk. I call it a vent now, lol
    SO where am I going with this, first off break downs are good, I got a chance to repaint my rig and tweak the setup.
    Venice- thanks, you are 100% correct, don't use dampeners, just bolt it to the frame, my bike has never been so smooth.
    I found some lead fishing net weights and stuffed my handlebars full -Awesome
    What to do with the rubber mounts? used them under my gas tank
    Still need to figure out a chain tensioning option. I think the top and bottom mount is the way to go.
    Here are some pics,
    Im hoping to get a new seat and a rear wheel.
    Is anyone using the HD wheel with the band brake?
    dnut
  2. 2door
    2door Moderator
    Staff Member
    16,301
    26
    Nice looking ride Heli,
    Sorry you didn't get the word about rubber mounts before you discovered why we recommend against them. There is a lot of good information here regarding the chain tensioner issue. Use the Google search feature and read all that is available from other members with tensioner problems. You're sure to find a fix.
  3. HeliHaole
    Jun 21, 2010
    15
    Thanks Tom,
    Yeah I just gottoa figure a way to attach a piece of flat bar to both the chain stay and the wheel stay, gotta learn to weld haha
  4. 2door
    2door Moderator
    Staff Member
    16,301
    26
    Welded is the best way, Heli, but several members have used clamps to hold the full span bracket in place. Another option, if you have the chain to frame clearance is to eliminate the tensioner. Some frames will require them and some, especially the ones with adjustable drop-outs will let you run without a tensioner. If you can get the chain to clear the frame and rear tire and still run true betwen the sprockets you should be good. Maintaining proper drive and pedal chain tension without an adjustable tensioner is the challenge. Good luck.
