the best 49cc engine
Discussion in 'Motorized Bicycle General Discussion' started by whitey, Mar 9, 2010.
  1. whitey
    whitey New Member
    Mar 7, 2010
    246
    looking on buying a 49cc 2 stroke chinese engine kit. Previously had a genII starfire angle head, thought it ran well. Is there anything better?
  2. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    Dealer rep for customer support is far, far more important than any ol' sticker on the side - some of these motors are lemons no matter the "brand name" ;)
    Other than that, check the forum - everyone thinks w/e "brand" they own is the best heh :D
  3. whitey
    whitey New Member
    Mar 7, 2010
    246
    what engine are you running?
  4. BarelyAWake
    Jul 21, 2009
    7,209
    I've had both two different "no name" 66cc's and two Grubee 66s (not all my builds tho)... all purchased before I figured out the dealer reputation thang (oops) :p
    Other than some minor variance in what was included with the kit - there's very little difference... the Grubee having only slightly better "accessories" like the twist grip... which in all honesty is still garbage lol
    The thing is no matter how "good" one brand is supposed to be over another, all have about an equal chance of being a dud, having shipping damage or simply being the wrong one. This is where dealer rep comes into play - it's all fine and good should you get a supposedly awesome brand ofn some random ebay distributor, but should you find some part overlooked or flawed - yer just screwed. Yet some of the better vendors are more than happy to go way outa their way to help their customers, doing whatever it takes to get 'em on the road, some even spending countless hours here - helpin' people figure out everythin' from strangest of issues to the most mundane.
    For a mere $10-20 difference or so - ya get those guys on yer "team", I'd say that's FAR more important than w/e sticker is on the side lol (I peel 'em off anyways) ;)
    #4 BarelyAWake, Mar 10, 2010
  5. Bikeguy Joe
    Jan 8, 2008
    11,529
    The best is the one you buy, and learn to tune and maintain. Not what some hype or sticker say is best.
    If you bought ten different engines (not looking at the accessories that come with them) put them in a pile and toss the hype out, you could reach into the pile of them blindfolded and your chance of getting a "good engine" or a "bad engine" would be 50/50.
  6. whitey
    whitey New Member
    Mar 7, 2010
    246
    thanks for the reply. Very helpful. Good to know that the engines are pretty much all the same so I don't need to fork out so much money.
    There is a guy selling the grubee engines close to me for $265 ,pretty expensive I think. probably get another cheaper it elsewhere.
    Just wanting to keep costs down as I want to get a shift kit as well.
  7. BarelyAWake
    Jul 21, 2009
    7,209
    ZOMG - $265 fer a Grubee 2stroke kit??? O.O
    Check out any of the vendors that have ads here, a full kit usually runs about $150... unless yer guy is sellin' 4 strokers - he's rippin' ppl off [​IMG]
    ...Then again I just noticed where ya live... *sigh* best of luck to ya, I've heard ya'll hafta pay a bit more :(
    #7 BarelyAWake, Mar 11, 2010
  8. Bikeguy Joe
    Jan 8, 2008
    11,529
    There are vendors in Australia.
  9. chopperjoe
    chopperjoe New Member
    Nov 15, 2009
    130
    Have a Grubee 48 cc and just received a Raw 66 cc. I have to say that the grubee came with better mounting brackets, and a variety of them, the Raw came with only two 1/8 inch mounting brackets, and no thick spacer for rear engine mount. Luckily I had left over from the Grubee supply. Also I drilled out the top throttle plate were the tab is located and drove a screw into the handlebar, a much more solid alternative to that little plastic tab wearing out in about a week. I thought the Grubee had a better fuel nipple coming off the carb, unlike the Raw just sticking straight up with no clearance for a thicker fuel line.
  10. vincent713
    vincent713 New Member
    Jun 2, 2010
    287
    Chopper, how is your 66cc compare to the 48cc? Is there really a big different in performance?
  11. chopperjoe
    Nov 15, 2009
    130
    The 66 cc has more power at bottom end, almost dont need to pedal to get going, but not good for the clutch. As far as speed the 66 cc seems to go a bit faster with more response at the throttle, still wasnt broken in when I sold it, had it up to 39 mph but pedal vibration was pretty intense. I weigh about 160 lbs. The Grubee just seemed to be a little better quality motor, with a better carb that has a banjo fitting, easier to use a thicker fuel line, unlike the straight up fittings that dont have any clearance. Best of luck. Chopper
  12. vincent713
    Jun 2, 2010
    287
    With that being said, I prefer my 49cc then. It's really smooth with hardly any vibration. Pick up speed is not that bad, I weight only 140.
