Tensioner yes/no
Discussion in 'Motorized Bicycle General Discussion' started by asianflava, Jun 14, 2010.
  1. asianflava
    asianflava New Member
    May 13, 2010
    57
    The tensioner that came with the kit didn't lineup at all and looked flismy, I ended up fabbing up my own out of flatstock and adel clamps. It worked fine, but the roller that I took off the kit tensioner is a bit short. There aren't enough threads to safely secure it to the mount. As proof, it came off the other day and broke the chain in the process of coming to a stop. Luckily I didn't dump the bike or hit the ground.
    I ended up removing the broken part of the chain and hooking everything back up. Now, both chains are nice and snug around their sprockets with the wheel set in place. It's like removing those couple of links took all the slack out of the chain.
    Should I bother with the tensioner anymore? I'd need to lengthen the chain at this point. What are the pros and cons of not using a tensioner? I've read a few of them in various posts along the way, but I can't find any one post that had both pros and cons.
  2. Whizzerd
    Whizzerd New Member
    Nov 20, 2009
    101
    You now have the best setup. If your engine chain is new it will stretch for around 150 miles or so. When I use a tensioner, it goes on the pedal chain side.
  3. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    I was lucky, when I bought my new engine/small sprocket, I didn't even need to use the tensioner. My chain has stretched a bit, but it doesn't seem loose enough to bother about a tensioner.
