Tcams unfortunate event
Discussion in 'Motorized Bicycle General Discussion' started by Tcams, May 31, 2010.
  1. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    Well After waiting a while to get my bike running with Jims new engine mount and sprocket adapter I finally got my bike running really good after a few fixable problems.
    A few days ago I was comming back from a ride around town and my chain popped off out of no where.
    . When I got home and inspected my bike I had noticed that one of the screws that holds my sprocket to the clamp was gone. Also I had lost a screw that holds the front clamp of Jims mount to the downtube. The threads in the adapter are pretty stripped so I dont think I will be able to use the adapter and what not.
    Also when the screw came loose that holds the sprocket it took some of my derailer with it. its not that bad but I just dont know how long until its gonna crack.
    I dont know what to do at this point. Should I get a new bike and start fresh?
    Hey Jim (creative Engineering) If I were to get a new frame could I send the clamps from my mount back to you and could you give me new clamps that will fit the new bike?
    Thanks
    Tcams
  2. GoFastBicycles
    GoFastBicycles New Member
    Jul 29, 2008
    560
    Sorry to see you had a bad day but that stuff needs to be checked every time prior to flight. Never just hop on and go your life depends on the PRE TRIP.
    Adam
  3. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    I check my bike before every flight. I should of used locktite on all screws. It was the vibrations after a long ride that loosened the bolts.
  4. city of angels
    city of angels New Member
    May 24, 2009
    470
    sorry to hear that hopefully he could give you a full refund
  5. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    I would talk to someone that can do drilling and tap-ing that can hold the parts ,and I believe we survive on loc-tite and checking bolts for tight,,,,,,,,,I know I've gotten lazy driving newer cars ,not like the old ones that got looked after often
  6. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    Well thats sucks Tcams, I'll get a hold of you this weekend if I get some free time and we will see what we can do.
  7. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    That adapter just needs to be drilled /tapped and then put a Heli coil in it and you will be good to go with it, and as was said by others.... Loc-Tite is a must on these bikes, I learned that the hard way as well, lost engine mounting studs and other bolts, these things have just the right kind and amount of viberation to knock all kinds of thing loose. good luck with your ride hope you can get it all fixed back up.
  8. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Got over 150 miles on my adapter and nothing's ever come loose. Took it off last week to go though the bearings on my rear wheel and it was just as tight as when I installed it.
    The trick is don't just use the allen wrench to tighten the bolts. I stuck a deep well socket that fit over the wrench on a 12" extension and used it as a "cheater bar" to torque down all the bolts.
    The adapter doesn't look that bad, you should be able to just use a tap to clean up the threads.
    This brings up a good point, you should always listen to your bike. If you hear something new or out of the ordinary stop and check things out.
    #8 Kevlarr, May 31, 2010
  9. Venice Motor Bikes
    Mar 20, 2008
    6,176
    I always use loctite on those bolts! (just in case) ;)
  10. wes
    wes New Member
    Aug 17, 2009
    207
    Thats a bummer Tcams, hope everything works out for you, its definitely fixable so don't give up on such a sick ride, good luck man. Ive been crazy busy and not much time on the forum but hopefully we can take a ride soon!! maybe a night ride down town.
  11. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    Im gonna see if USA bike motors can fix up my sprocket adapter, They have all kinds of tools.
    What should I do about my frame, Is there any kind of liquid cement or something that will make it stronger? That scares me
  12. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Best thing to do is (no joke) file or sand the area that's scarred smooth, paint it then keep a close eye on it. With it being painted any crack that starts to develop will be easy to spot. That's a pretty strong spot on the frame since the dropout extends into the chain stay tube so I doubt anything will happen to it.
  13. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    thanks Kevlarr.
    I will be doing that ASAP.
    and thanks everyone for your help
  14. bairdco
    Aug 18, 2009
    6,352
    28
    those three sprocket bolts are the only part on my bike i use loctite on. i was doing about 40 and had a bolt back out on me and catch my coaster brake arm, locking my wheel and sending me into a 100' skid.
    luckily it didn't do any other damage and i was able to limp the bike home.
  15. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Did you leave a double skidmark? I think I would have. lafff
  16. bairdco
    Aug 18, 2009
    6,352
    28
    i just turned off of a heavy traffic road, where i was riding in the lanes with the cars onto a bike path when it happened.
    a few minutes earlier, and there woulda been a a few bloody skidmarks from the cars behind me...
    yeah, it was sketchy.
  17. troyboy
    troyboy Your East Coast Gasbike Connection
    Apr 18, 2009
    171
    Tcams,
    If you can't get your adapter repaired. I will send you a new adapter with the necessary hardware to get you back up and running. Its a rare issue and I will help you out if need be. Not sure if Jim has any CB- 110's in stock.
    Let me know how you made out at USA Bikemotors.
    You should use blue loctite on your sprocket bolts. First tighten the adapter really good then tighten the sprocket as tight as you can by hand. After that put a cheater bar over the allen wrench and give it a little more. Don't worry the sprocket bolts won't strip from over tightening them.
    Always keep your eyes and ears open. Things usually make a funny noises before they go haywire.
    Justin
  18. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    Hey Justin..Just got back from USA bike motors and they fixed my sprocket. They just rethreaded everything and the bolts go in smooth again.
    I still need 2 screws that hold the sprocket to the adapter.
    Thanks Justin.
  19. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    Thats great to hear Tcams (^)
  20. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    I wish I knew you were going to usa today, I would have cruised over there and hung out. Those guys are great.
