Tank Prep Media Question
Discussion in 'Motorized Bicycle General Discussion' started by GasX, Oct 30, 2011.
  1. GasX
    GasX New Member
    Oct 7, 2011
    277
    I have seen numerous recommendations to shake some gravel in the stock kit tank before use to shake off any rust. Any thoughts on using a generous amount of Kosher salt? Abrasive, cheap and easily disposed of...
  2. leadfarmer
    leadfarmer New Member
    Sep 30, 2011
    149
    Wouldn't you have to use water to get it all out? Water seems like a bad thing to put in your tank. I just used BB's from Walmart. They are cheap, and you can tell when you have them all out.
  3. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Sand? It's even cheaper than salt.
  4. thegnu
    thegnu New Member
    Sep 15, 2011
    982
    muratic acid is the answer here just be extreemly carefull with it , or concentrated aluminum cleaner also has a mild to strong acid in it , to neutralize the acid use a solution of baking soda water mixed very weak as it will create a gas you dont want to breathe , then into a 150 degree oven to rapid dry it out or simply let an air hose open in the tank to evaporate the moisture quickly . or go to a auto body supply store an purchase any good metal prep product they leave behind a zincphosphorus coating inside the tank when dry to prevent further rust developing .
  5. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    I used naval jelly and water to dissolve the rust. Sealed off the openings with duct tape and shook and checked until the rust was gone. Then a thorough water rinse followed by a rinse with isopropal alcohol to dry out all the water.
    Then I sealed it with POR 15 so I wouldn't have to worry about bad welds.
    So far, so good. No leaks, no sediment in my visable fuel filter.
  6. vincent713
    vincent713 New Member
    Jun 2, 2010
    287
    I really don't see why water is such a bad thing, rinse it out thoroughly and wait for it to dry. What would really happen if few drops of water gets into the engine while running?
  7. GasX
    GasX New Member
    Oct 7, 2011
    277
    I was thinking a high tech leak test with coca cola followed by a few rubbing alcohol rinses would result in a clean dry and rust free tank. My eyeball test today showed a pretty clean tank, so I am not too worried about more aggressive measures...
